Carbon Fiber Group Buy #2 R32/r33/r34/r35 Evo Etc 2/4/15 New
Starting a group buy #2 for Carbon Fibre \ FRP goods as i have been asked by a few guys we need at least 10+ Buys to get a decent discount
Company called : Wujiang Jianwu we have bought from these guy's before with no issue's
Start Date 4\2\2015 END 4\5\2015 ( I am able to put the order of 10 in whenever )
Seller takes USD
Prices all ALL APPROX might increase \ decrease Slightly depending on our $ and how much items we buy. The More the cheaper. Final Prices will be confirmed after order put through.
Will also confirm prices on shipping after order has been made.
Pick up welcome south western Sydney suburbs.
All items are wet lay carbon or vacuum infused carbon, so its carbon layer on top and FRP base.
R35 GTR
Hood
Spoiler
Hood Vents
Diffuser Blade
Engine Cover Set
Gear shroud centre console
Zele side skirt , Front and rear lip
R34 GTT \ GTR
* R34 GTT cooling panel $110
* R34 GTR OEM rear bumper exhaust shroud - $80
* R34 GTR Nismo front lip - $250
* R34 GTT/GTR wind deflectors - $50
* R34 GT/GTT/GTR passenger headlight intake - $170
* R34 GTR JUN High wing stands - $190
*R34 GTR z tune front bar - $350
*RB26DETT coilpack cover - $120
*R34 eye lids
R34 Door Sill - $130
R34 GTT \ GTR canards 4 Pieces - $130
R34 GTR Oem rear bumper diffuser add on - $220
R34 cf boot
R34 front splitter cf $ 350
R34 Auto select front splitter $370
R33 stuff
* R33 B-Pillar Covers - $100
* R33 GTR rear spoiler end caps with "GTR" logo
* R33 GTR OEM rear bumper exhaust shroud - $70
*R33 eye lids $80
*R33 mirror covers
* R33 GTS/GTST S1 Garage defend style radiator cooling panel (will not fit GTR) $130
* R33 fuse box $120
* R33 wind deflectors $157
* R33 GTR OEM wing blade $180
* R33 GTS/GTST/GTR A-Pillar twin gauge pod suit 52/60mm $150
*R33 GTR front OEM gril (suit GTR only) $150
*R33 GTS/GTST - GTR Style front grill (suit GTS/GTST only) $150
*R33 GTST/GTR Top Secret Style diffuser with universal fitting brackets Type 1 or 2 $470
* R33 GTR/GTS bonnet lip $100
*RB26DETT coilpack cover $130
*RB25DET plug cover $130
R33 Jun Lip $250
R32 stuff
* R32 Dash mount double gauge pod Suit 52/60mm
* R32 GTR radiator cooling panel
* R32 GTS/GTST/GTR wind deflectors
* R32 GTS/GTST/GTR headlight intake
*R32 GTR/GTST mirror cover
*R32 GTST/GTR Top Secret Style diffuser with universal fitting brackets
*R32 GTR OEM front grill
*R32 GTR bonnet lip
*R32 GTR/GTST eye lids
*RB25DET S1 & S2 coilpack cover (has screw fittings for ignitor)
R32 Jun Lip $250
R32 AB Flug Lip $240
S15 stuff
*garage defend style radiator cooling panel
*rear bumper exhaust shield
*vented headlight covers (both left & right)
*mirror covers
S14 stuff
*ABS cover
*vented coil pack cover
*oem coil pack cover
*mirror cover
*eye lids
CT9A - Evo 7/8/9
* evo 7 OEM
* evo 7-9 side skirt add -ons
*evo 8 front bumper canards
*evo 8 radiator cooling panel
*evo 9 OEM rear bumper add on
*evo7-9 rear boot spoiler lip (fits with original spoiler)
*evo 9 varis style rear bumper exhaust shield
*evo7-9 wind deflectors
*evo7-9 eye lids
*evo 7-9 mirror covers
Can also get Fender's, Bonnets, Spoilers, Diffusers etc for most JDM cars.
If you don't see a item on the list let me know and ill find out. I think i can also order in some bride seat's
Longz : R35 varis vents , emblem cover , exhaust shroud , bonnet scoop , front grille , engine cover , center console , top secret front lip , zele side skirts ( yes i am hunting for a r35 )
R33 stuff
Put me down for these please
raj : R34 CF boot is $380 no boot lip's but i can get the 32 one and see how far off it is on my 34 lol and yes B pillar covers $130
jaeyon :
*R32 GTR/GTST mirror cover mirror cover $120
*R32 GTR bonnet lip $120
*rb26 coilpack cover $130
current list :
.:: GimpS-R34 ::. : * R33 GTR OEM rear bumper exhaust shroud - *RB26DETT coilpack cover
i need one if this is the factory one not the carbon fibre one
Edited by samrazor
Samrazor : they are carbon fiber ones.
Supra Mk4 :
1993-1998
TRD Spoiler
2JZ engine cover
Fuse Box Cover
Cooling Panel
Arm Rest Cover
Gauge Pod
Radiator fan cover
interior trim 13 piece set
blitz side skirts
vvti engine cover
Please can I have prices on the following?
TRD Spoiler
2JZ engine cover
Cooling Panel
Can I also have pictures of the below item?
They dont make a 'Top Secret Style' diffuser for the supra do they??
IcedTea : $140
Albo :
TRD Spoiler 3 piece : $370
2jz engine cover : 190
cooling panel : 190
TRD 13 piece interior trim $650
I think you can use the r33 top secret diffuser and modify it to suit the supra lol
current list :
nism26 : R34 wing stands and r34 door sills
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
