up for sale is my godzilla immaculate condition inside out very rare to find in this condition have spent around 10k on just bolt on mods also the car got a full respray 5 months ago body is very straight big money spent on this gtr..has 127,000 kms Never been in any type of accident all gaps,panels are all factory.. No rust or dents, paint job still looks fresh always covered in the garage..
Major service done not long ago includes water pump timing belt kit engine mounts and a few other bits..Pushing a safe 305kw at the wheels recently tuned by unique automotive.. Can easily push 350kw+
Factory Front and rear strut brace
Factory Nismo cluster
N1 headlights
Hks gtrs turbos rebuilt 2 weeks ago with receipts
Trust down pipes
Catch can
Rc racing injectors
Apexi Power fc
Greddy profec B Spec 2 boost controller
Garret boost gauge
Rda slotted rotors front and rear
Rare kakimoto titanium exhaust this will Only be included for the right price otherwise it will come with apexi exhaust
$24500 negotiable.. 1 year rego No stupid offers need to know anything else contact me on 0434496255 post-127910-14230334451178_thumb.jpgpost-127910-14230334582498_thumb.jpgpost-127910-1423033469219_thumb.jpgpost-127910-14230334787374_thumb.jpgpost-127910-14230334957537_thumb.jpgpost-127910-14230335067483_thumb.jpgpost-127910-14230335217239_thumb.jpgpost-127910-14230335320312_thumb.jpgpost-127910-14230335439994_thumb.jpgpost-127910-14230335557182_thumb.jpgpost-127910-142303356525_thumb.jpgpost-127910-14230335732726_thumb.jpg
https://www.sau.com.au/forums/topic/453489-immaculate-r32-gtr/
Hey guys cylinder #5 lost compression a few days ago the car is still forsale for the right price, I'm not letting this go for dirt cheap the car is immaculate and if you have a built motor this is perfect for you, for more details text or call me on 0434496255 also if It doesn't anytime soon I'll be building the motor
so what's the price for the car now?
Lost how much compression, as in all? Or just from 160 down to 140?
Or has it contracted the dreaded and heavily contagious Holeinpistonitis?
If so what sort of dollars are you looking for considering it needs a new motor?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
