Japan forum regulars,
Guys, I've just moved house and I won't have ADSL access (40 Mbp/s mind you) for another 2 weeks, so hang back with those 1/24th die cast model orders etc ok?
So it'll be Rezzless around here for awhile... I haven't buggered off, just letting you guys know!!! :cheers:
When I come back I'll have a "Photo Diary" update and I'll sort those model car orders out etc, etc...
p.s. Special thanks goes to Troy (Evil_Pee... I mean "Evo_Lee" :D) for sacrificing his Mitsubishi Evo 5 all day last Saturday during 35 degree heat helping me move house... well done lad, u da man!!!
https://www.sau.com.au/forums/topic/45364-message-from-rezz/
Your welcome Lezzbian...I mean Rezzbian :cheers:
LOL...only the delicate goods and packages went in the Evo, but the Lancer does have a big trunk so it was all good, only needed to make 2 trips. The rest of Justin's funiture went in the removal truck, have to also give a big thanks to removal guys for working 5hours in the atrocious heat and moving all this stuff up 5 flights of stairs to Justin's new place.
If you want to know how hot it was, well we manage to sneak away to the local Super AB mini car show for an hour and this is what 35+ degree heat does to a carbon bonnet...STILLWAY Evo7.
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-924196
Your welcome Lezzbian...I mean Rezzbian ;)
i dont see it. is it twisted/melting?
dont car engines run at temperatures above 35c =)
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-935140
Huh...:confused:
Course carbon can withstand high temperatures before it fails and melts through...but with all material there is a transition state. Carbon will not flex that much under it's own weight, sitting under the sun all day at that temperature the bonnet was obviously starting to droop and flex like rubber.
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-935674
Perhaps it's the angle of the photo. Course CF can withstand high temperatures before it fails and melts through, but with all material there is a transition state. CF bonnets doesn't flex that much under it's own weight, but sitting under the sun all day at that temperature the bonnet was definitely more then 35-37.5 degrees and she was drooping and a little flexy.
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-935773
wtf is T3? 3,000mbp/s? I'm at home... are you? If you are, pat yourself on the back!
Monkey... I'm detecting some kind of competiton or something going on with you... it seems that almost everything I do, you gotta come back and say something to the tune of "I see your ***** and raise you ***** ". I'm not having a rant, but if you wanna annoy/irritate/rev me up, at least make it funny!
3 words dude: I'm not interested...:cheers: now can we get on with the job of producing the best Skyline website on the planet?
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-939980
yeesh, ease up rezz, it was a mildly humoured statement... and no i'm at Uni (hence the T3, see you were supposed to ask how I was on a T3 which i would use as a conversation point to tell you why i was at uni) but anyways, I'll catch ya later on some other thread.
PS did you get my PM about thoses discs?
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-940004
OK, 私はあなたを最近悩ますことを残念に思います。 私は、あなたがチャーミングなユーモアを回復することを望みます。 sock 材料を除外します。 ^__^
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-940054
You did NOT write that yourself did you... the dictionary style language gave it away. But yeah, I'll leave out the sock bizzo :D
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-940847
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
