Japan forum regulars,
Guys, I've just moved house and I won't have ADSL access (40 Mbp/s mind you) for another 2 weeks, so hang back with those 1/24th die cast model orders etc ok?
So it'll be Rezzless around here for awhile... I haven't buggered off, just letting you guys know!!! :cheers:
When I come back I'll have a "Photo Diary" update and I'll sort those model car orders out etc, etc...
p.s. Special thanks goes to Troy (Evil_Pee... I mean "Evo_Lee" :D) for sacrificing his Mitsubishi Evo 5 all day last Saturday during 35 degree heat helping me move house... well done lad, u da man!!!
https://www.sau.com.au/forums/topic/45364-message-from-rezz/
Your welcome Lezzbian...I mean Rezzbian :cheers:
LOL...only the delicate goods and packages went in the Evo, but the Lancer does have a big trunk so it was all good, only needed to make 2 trips. The rest of Justin's funiture went in the removal truck, have to also give a big thanks to removal guys for working 5hours in the atrocious heat and moving all this stuff up 5 flights of stairs to Justin's new place.
If you want to know how hot it was, well we manage to sneak away to the local Super AB mini car show for an hour and this is what 35+ degree heat does to a carbon bonnet...STILLWAY Evo7.
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-924196
Your welcome Lezzbian...I mean Rezzbian ;)
i dont see it. is it twisted/melting?
dont car engines run at temperatures above 35c =)
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-935140
Huh...:confused:
Course carbon can withstand high temperatures before it fails and melts through...but with all material there is a transition state. Carbon will not flex that much under it's own weight, sitting under the sun all day at that temperature the bonnet was obviously starting to droop and flex like rubber.
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-935674
Perhaps it's the angle of the photo. Course CF can withstand high temperatures before it fails and melts through, but with all material there is a transition state. CF bonnets doesn't flex that much under it's own weight, but sitting under the sun all day at that temperature the bonnet was definitely more then 35-37.5 degrees and she was drooping and a little flexy.
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-935773
wtf is T3? 3,000mbp/s? I'm at home... are you? If you are, pat yourself on the back!
Monkey... I'm detecting some kind of competiton or something going on with you... it seems that almost everything I do, you gotta come back and say something to the tune of "I see your ***** and raise you ***** ". I'm not having a rant, but if you wanna annoy/irritate/rev me up, at least make it funny!
3 words dude: I'm not interested...:cheers: now can we get on with the job of producing the best Skyline website on the planet?
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-939980
yeesh, ease up rezz, it was a mildly humoured statement... and no i'm at Uni (hence the T3, see you were supposed to ask how I was on a T3 which i would use as a conversation point to tell you why i was at uni) but anyways, I'll catch ya later on some other thread.
PS did you get my PM about thoses discs?
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-940004
OK, 私はあなたを最近悩ますことを残念に思います。 私は、あなたがチャーミングなユーモアを回復することを望みます。 sock 材料を除外します。 ^__^
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-940054
You did NOT write that yourself did you... the dictionary style language gave it away. But yeah, I'll leave out the sock bizzo :D
https://www.sau.com.au/forums/topic/45364-message-from-rezz/#findComment-940847
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
