sometimes, well most of the time i have it flat stick or slight throttle it bounces off the limiter and bogs down, missfires and slowly looses revs and power, its like what happens when your spark plug gap is ****ed...it was doing it with a gap of .8 then i went to a .7 but still does it. if i back off and back on the throttle it will sometimes get better but once it hits the limiter again itll bog down, missfire and loose revs even with foot flat or slightly, its like as if its surging out. this is mainly halfway through a slide (off street). all i want it to do is bounce off the limiter cleanly for peace at mind.
whats a solution? should i close or open gap more or is it something else? timing perhaps? i got no idea
cheers.
https://www.sau.com.au/forums/topic/45365-rb25det-off-limiter-bogging/
The R34 will happily bounce off the rev limiter all day.
It used to be a slow pop pop pop as it hit limiter and then dropped spark then picked up again, but now with the light flywheel, its like a machine gun!
Nice.
Could be coils if it starts happening before you get to the limiter - mine starts misfiring at around 4500, and I don't usually see more than that because it feels terrible.
I understand that the car isn't running properly, but why do you want it to bounce off the limiter? If you're accelerating, hitting the limiter is costing you time, if you're doing a burnout, backing off the throttle a fraction should make bugger-all difference to smoke output, and if you're trying to drift, hitting the limiter generally means that you either have no throttle control or you're doing it wrong.
Learn throttle control - your car will thank you for it, and you'll be a better, quicker driver.
its not that i bounce it off the limiter often, its just the satisfaction that it will run cleanly if need be. all these people are sayin learn throttle control, learn throttle control, when clearly its not about that, i must explain a little better, as SOON as it hit the limiter, no bouncing off it, even without WOT, it still does it, sometimes doesnt even need to hit limiter, it just goes BRRRRR, looses revs and power and sometimes backfires hard. always when its under load.
sorry to confuse the subject but yea im not one of these 'lets just flatten it around a corner' style drivers.
  • 9 years later...
