Ok so I am nearing an end to my R34 GT-T to GT-R conversion. the motor, transmission and front diff are all from a R32/33 GTR not the R34 so the trans is a 5 speed and the front diff ratio is 4.11.
I just got R34 GT-R front and rear subframes complete with suspension, brakes, rear end, steering (front and rear although i am deleting the HICAS) . the rear diff is 3.54 ratio so i will need to swap that to a 4.11 to match the front diff. I also noticed that the Attesa ETS pump was not on the rear diff and subframe assembly. I thought that the attessa pumps were mounted on the Diffs on all years. I just got an R33 GT-R rear diff (4.11) and it has the pump mounted right to it. the housings to both diffs are very similar except the pointing points for the Attessa pump are not on the R34 GT-R rear end. was it located else where?
also a few other things i noticed. the bolt flanges on the R34 and R33 rear ends for the CV shafts are different. so I will not be able to run the CV shafts i have in my completed R34 GT-R rear subframe assembly if i put the R33 GT-R rear end in it.
does anyone know if i can take apart the diffs and put the ring and pinion or entire assembly from the R33 diff into the R34 housing?
OR can the part that comes out of the rear diff and has the ABS stuff on it and mounts to the CV shafts be swapped over to the other diff? basically put the abs/inner shaft part into the R33 diff so it will still bolt up to the R34 CV shafts?
hope this all makes sense. I am uploading pics also. hang tight i will post them shortly
All GTR axles are 6 x 1. They are thicker and stronger than the GTT. You will have to find a way to mount your attessa pump. I will look under my car later and see how it was done, We also change over the abs rings. The 3.54 diffs are sought after so you should have no trouble selling it.
first pic is the R33 GT-R rear end. 3 double bolt flange for the CV shaft.
the second pic is the R34 GT-R rear end. notice the evenly spaced 6 bolt for the CV shaft. can that cv shaft "yoke" with the ABE ring on it be pulled from the R34 GT-R rear end and put in the R33 GT-R rear end?
ok info update. i guess the rear end i bought was from an R33 Stagea. that is why its different. anyone know if the parts are interchangable? can i put the CV "yoke" (with the ABS stuff on it) from the R34 GTR rear end in this R33 GTR or i guess Stagea rear end?
OK by now you see that 6 x 1 is the bolt arrangement - the Stagea is 3 x 2. The Stagea diff will have either a crappy viscous LSD or no LSD so it is not much use to you. You may be able to get the R34GTR diff to work by changing the C&P if it was not a V spec but you will need 6 x 1 axles of the right length. The Stagea crownwheel and pinion is close but not exactly the same as the GTR ratio. It may still pay for you to look for an R32 or 33 GTR rear end - you should be able to sell the R34GTR no problem.
thanks for the reply!
over the weekend in removed both the inner half shafts out of the rear ends. the 6x1 GTR R34 rear end is 32 splined, the R33 stagea 3x2 are 30 spline so i was un able to put the GTR shafts in the stagea rear end.
next option, is what you said. I am trying to see if i can take the 4.11 C&P out of the Stagea rear end and swap it with the 3.54 C&P in the R34 GT-R rear end.
you said the ratio from the stagea R33 rear end is close but not the same as the GTR. the research i did i found that the R34 GTR is not close at all (3.54 ratio) while the R33 and R32 GTR have 4.11 ratio, as well as t he R33 Stagea (4.11) my front diff is 4.11 so ratio wise i should be dead on. correct?
my only question is the C&P directy swappable from the R33 Stagea rear end to an R34 GT-R rear end. the rear end i dont believe is a vspec, no coiling fins and i dont think it has A-LSD due to no fluid lines coming from the rear end other that the one vent tube.
Sorry I meant Stagea at 4.08 is close to the R33GTR 4.11 diff which you have in the front - I assumed you would not be using the 3.545 out of the R34GTR diff. I don't know if the Stagea CW&P will fit the R34 LSD diff - you will soon know - and as I say there is a small difference in the ratio but it may not be significant or you can overcome it with wheel/tyre combinations. I do think the 6 x 1 axles can fit the Stagea hubs as I have 6 x 1 axles in my Stagea (although I think the GTR hubs may be lighter than the Stagea ones if you want to saveweight) but you need to carefully check the lengths as in some case an axle may be an inch or less too short and fall out! 6 x 1 axles are found on all GTRs, GTS-4, some 300Z and the Stagea 260RS (pretty rare in the US I would think) and not all are the same length including being different left and right.
hmmm so the stagea isnt a 4.11 rear end ratio? the company a purchased it from said it wass a 4.11. but then again they also sold me a stagea rear end not an R33 GTR, and when i confronted them they said they were the same, so then i proved them wrong and they were like oh we learned something new. I can return it but id have to pay the return shipping and that costs almost as much as the item.... DAMN having little to no support for skylines in the US!
to answer your question about the GTR R34 axles fitting in the Stagea rear end, they do no. the R34 GTR has a 32 spline shaft going into the rear end. the Stagea only has a 30 spline.
are you 100% sure that the stagea rear end is not 4.11? and its 4.08? that worries me that they will be off
I didn't say the GTR axles would fit in the Stagea diff I said the other end would fit in the hubs.
However if your diff was from a 260RS you are in luck as it will be 4.1 (you can easily check by counting the teeth on the pinion and the CW) and also it will have a proper LSD
Sorry I miss understood you. I am also lead to believe that the Stagea axles are not as long as the R34 GTR axles. not sure 100% tho. either way I dont even have the stagea axles, just hte inner half shafts.
You don't even have to count teeth. The ratios are stamped into the edge of the crownwheel.
I will inspect tonight
I contacted the seller to see what Stagea this mystery rear end is out of. but i saw the rear subframe it was pulled from, was equipt with black brembos. they had a matching front subframe i also believe was from the same car in the background of the pictures, also had black brembos and was AWD. so im assuming it was the AWD RB26 Stagea. so if that chart and my thoughts are correct I have the 4.11 rear end/
you were correct. the rear gear ratio was 4.083. we took it apart over the weekend and checked.
so i guess im in the market for a 4.111 ring and pinion gear set. would like it to fit the R34 GTR rear end (non active LSD)... i believe the rear end is the R200h? will a standard 4.111 ring in pinion work thats for an R200?
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
