apologies if this is in the wrong location, not sure where to post this.
My Rb25/30 in my vl refuses to start.
Was previously running as a single t3 setup, moved to bigger hotside now wont start.
Car currently cranks but gives no hint of starting.
Have checked the following:
Has Fuel - Have gone as far as removing injectors to ensure that each is firing.
Has spark - have removed all 6 coil packs with plugs in and have seen spark from each, looks quite strong.
Has correct timing - both cam gears line up with markings as well as the balancer is lined up. Even removed the intake cam cover and ensured that the 1 valve is pushed down at the moment of TDC (had originally had it 180 out but this has been fixed)
Has Air - removed cooler piping, just straight opening from the TB.
Has compression.
Things I have tried:
- The old start ya ******* in the intake, still no sign of start.
- Fuel directly in the cylinders, still no signs.
Is run by a Wolf ( please dont suggest that I should bin this, was working previously)
I appreciate if anyone has any other suggestions for me to try? I am all out of ideas.
Need anymore info let me know!
https://www.sau.com.au/forums/topic/454099-rb25-wont-start-please-help/
Yeh CAS seems ok. Lined up where previously working. If I take CAS out and spin it ticks the inj so I presume it is functioning. I do have two CAS that both worked and no difference between either. Surely I havent broken both by having them sit around!
Anything else you could think of?
A suggestion, try to list the sequence of events, otherwise we're just guessing.
eg
Car was running perfectly and I only fitted a new turbo, now she won't start.
OR
Fitted new turbo, manifold, cam belt etc, etc
Just a heads up, TDC/firing on No1 will have all No1 valves closed.
TDC/firing on No6 will have inlet and exhaust valves swapping over on No1.
Thanks for the reply. WIll have to double check than but have tried the timing with all 3 marks lined up and than also rotated the crank one turn and tried lining them up there, but to no avail. Just to clarify, I need to have the valves on no1 on both sides closed when its a TDC and than put the belt on there?
Sequence of events is a little more to it than that so ill list them out.
It was running perfectly as a 25/30 with a t3.
Than upgraded the following:
- Manifold plus twin t
- 044 plus surge / top feed 650cc inj / new FPR.
- changed rb30 oil pump to the rb25 oil pump
- changed balancer over to a smaller one without a air con pulley.
- went to 80mm TB
Coil packs cas etc are them same and std.
Still using the wolf.
Any help from here is appreciated
you are correct, ignore my comment on turbo. it has a small one now it has two big ones, is that enough info?
In regards to inj, no I have not made any adjustments in wolf.
Car has not made a splutter, so I am not sure this would effect it from trying to start?
Either put old injectors back in or get someone to change settings in the ecu.
They spray way too much fuel therefore car doesn't start.
I win this thread.
Just curious how big were previous injectors?
Edited by Ben C34
Cant swap in old ones as they were the std side feed and I've got top feed with new lines etc. Dearly noted will get the wolf updated for the new ones. But seriously would having to much fuel mean the engine would not even try to start? The issue seems more sinister than that. Any more ideas let me know mate
I completely agree with ben with the larger injectors without a tune wpuld deffinatly be flooding the car and causing it not to start. I noticed you have a aftermarket fpr. I had something similar happen to me when i changed my injectors over from stock to 750cc top feeds what we done was turn down the fpr reducing the fuel flow and that got it started and got it to the tuners. So maybe even give that a try. I had mine turned down to 1bar
  • 7 months later...
But you said that you had fixed this....when I [just now] read the thread my first thought was timing is out 180'.........but you said you'll fixed it so I - like many others here - discounted that idea straight away.
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
