Come on guys I've have to sell my turbo and parts - NOW
MAKE OFFERS AS I WILL CONSIDER ALL OF THEM - I HAVE TO SELL !!!!
Bought to suit high hp RB25/26 for my R33
Turbo - SOLD !!!
Also have the following (ALL BRAND NEW)
Haltec E6X ECU with 3 bar map sensor and all wiring etc needed to fit. $1500.00
Meziere remote elect. water pump.(will never get hot with this baby)
Edlebrock elect. fuel pump 80gph flow rate with mounting kit and Edlebrock high hp regulator. $700.00 ono
Large Permacool engine oil cooler with remote oil filter adaptor and hoses. $300.00
PLUS USED BITS
JIC coilovers - SOLD !!!
PM me or ph. 0416350750 (Chris)
https://www.sau.com.au/forums/topic/45410-performance-parts-fs/
GTTR34 - no pics at present. Will get some tonight and post in the morning. If you go to Garretts site you will see it on there though.
Cyclonus and Skyrine_Dave - picking up copies of my receipts after work - will pm prices after that.
but they will be a lot less than I paid.
95GTST - thanks - I will email now.
  • 3 weeks later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
