Don't rely on that remedy too much as eventually it will probably just die on you, best bet is to just but a new afm and be very careful when installing it, making sure you don't knock it or anything like that. For me the afm took a couple of weeks of running in for it to get rid of all the shakes. I'm just going off what happened to me when my afm shit itself and now my car runs fine. So I hope that helped mate and good luck :cheers:
Could have been just a loose plug by the sounds of your remedy. Wait to see if it happens again before spending cash on new.
No way will you get a new genuine AFM for $100 bucks. It's likely second hand for that price and could well be dodgey too.
New would be sub $300
If you still have the old AFM, take the cover off it on the side (the black square thing) and check the solder joints where the plug contacts meet the afm contacts. Mine has done this few months and and it's a 5min fix as the solder joints dried up.
If that's the case, take the plug out, clean everything and then re-solder the contacts, pop it back in and drive for a day or two to make it's all good. Than way you have a spare afm and have learned something in the process.
Edited by ErOR
Don't worry about it, people don't listen, people would rather spend $380 than follow a diy that would take them 30 minutes and $30 on an iron and solder. It's such an easy fix for such a common problem. I just don't understand.
