slickmick14 Posted March 1, 2015 Share Posted March 1, 2015 hey guys, im a newbie, i know this has been covered before, but i cant find it. just got an m35 series 1 vq25det still learning. the tps just shit its self, do all vq throttle bodies fit? Link to comment https://www.sau.com.au/forums/topic/454337-tps-problem/ Share on other sites More sharing options...
Daleo Posted March 1, 2015 Share Posted March 1, 2015 Not tps; AFM is the issue. Buy a spare from Scotty's customs. Better to have a spare and not need it; than need a spare and not have one. Link to comment https://www.sau.com.au/forums/topic/454337-tps-problem/#findComment-7489035 Share on other sites More sharing options...
slickmick14 Posted March 1, 2015 Author Share Posted March 1, 2015 Error code came up as traction control throttle problem. Link to comment https://www.sau.com.au/forums/topic/454337-tps-problem/#findComment-7489080 Share on other sites More sharing options...
Daleo Posted March 1, 2015 Share Posted March 1, 2015 Stagea's don't have traction control. Link to comment https://www.sau.com.au/forums/topic/454337-tps-problem/#findComment-7489112 Share on other sites More sharing options...
slickmick14 Posted March 1, 2015 Author Share Posted March 1, 2015 The mechanic told me the scanner came up with tcs error. I assumed that ment traction control. He was the one that told me to change the tps. Link to comment https://www.sau.com.au/forums/topic/454337-tps-problem/#findComment-7489126 Share on other sites More sharing options...
scotty nm35 Posted March 1, 2015 Share Posted March 1, 2015 His scanner actually read it? What are the symptoms? TPS errors make the car obviously in limp mode, the throttle won't work at all. Link to comment https://www.sau.com.au/forums/topic/454337-tps-problem/#findComment-7489221 Share on other sites More sharing options...
slickmick14 Posted March 1, 2015 Author Share Posted March 1, 2015 Yep. Throttle won't work at all. Only idle. He cleared the error and went to drive it again, went straight back in to limp mode. Link to comment https://www.sau.com.au/forums/topic/454337-tps-problem/#findComment-7489283 Share on other sites More sharing options...
Daleo Posted March 2, 2015 Share Posted March 2, 2015 Hmmm, does sound like a failure. I believe that the VQ35 tb is compatible, but Scotty would know for sure. Link to comment https://www.sau.com.au/forums/topic/454337-tps-problem/#findComment-7489308 Share on other sites More sharing options...
scotty nm35 Posted March 2, 2015 Share Posted March 2, 2015 I think it might be, but I have a few throttles here off turbo motors anyway if you need one. Where are you located Mick? Link to comment https://www.sau.com.au/forums/topic/454337-tps-problem/#findComment-7489438 Share on other sites More sharing options...
slickmick14 Posted March 2, 2015 Author Share Posted March 2, 2015 Adelaide sa Link to comment https://www.sau.com.au/forums/topic/454337-tps-problem/#findComment-7489479 Share on other sites More sharing options...
