Just wondering if anyone has put an air bag suispension in a c34 stagea?
Thanks to my Takeros front bumper i cant go any coilovers (currently sitting 105mm from ground @ a 380 ride height with any coilovers dropping ride height to 365 at heighest point bringing front bar to just 90mm from the road) and stock replacement is non existant in brisbane apparently so it has to be custom springs ect which is gonna cost me around 1453 (fitted so not too bad) but wouldnt mind being able to raise it to get into my driveway rather than having it sitting on the road waiting to be hit again.
Any info would be great, dont mind having to travel a bit to speak with someone with some knowledge about options. Cheers
https://www.sau.com.au/forums/topic/454432-air-bag-suspension-c34-stag/
Somebody makes kits for just that job - not replacement suspension but just a booster for getting into parking buildings etc. I'll have a look but last saw it a few years ago.
Had a quick Google and BC actually make one (not the one I saw before but...) called Aircup
There's a few air suspension kits for r33 and 34 skylines, I presume one of those would fit. I'm in the stages of bagging a Pmn35 Stagea and there was no kits that I could get my hands on, luckily 350z has the same setup as a m35
  • 3 weeks later...
did a fair bit of hunting around for these, saldly i couldnt find anyone with a direct fit kit (make it easier and cheaper so i can install myself), cheapest quote i got was $4500 installed... with parts being roughly $3000 and they wouldnt sell just parts so for the time being thats just gonna have to wait i guess...
  • Like 1
You won't find a specific kit in australia, maybe in Japan though. As I said above, it'll be easier for you to find a car that shares the same suspension and look for a kit to suit.
$4500 installed isn't that bad considering my M35 install is going to cost $4400 just in parts. What air managment system and struts are you looking at using?
i couldnt tell you to be honest, they did tell me but i cant remember, was going to be tripple front and rear with a removeable controller hidden in the center colsole, tank behind the rear bar and all the pistons ect in the spare wheel well.
Though Ive decided to go back to stock height shocks+springs with swaybars front and rear, need to keep my car legal at the moment and according to QLD Transport if i bag the stag it wont be legal on QLD roads and because of this my insuance company wont accept any claim if anything does happen... which sux.. gonna leave it for a year or two till im ready to do some more then reassess.. would still love to put bags in though.
  • 11 months later...
What happened with this? Anyone find where to buy air bag suspension kits for c34 s2 Stagea?
Doubt you'll find any c34 specific kits from well known brands (airrex, airrunners). As long as 33 or 34 skyline struts fit in the c34 there's plenty of kits out there
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
