G'day just in need of some advice, currently having my rb25det rebuilt,
Mods relevant to the issue are
Cp Pistons Sc7305 86.5mm 9.0:1
Bridgeway forged rods
Block was decked
Been told Comp ratio is only 8.4:1 and pistons are .029" out of the block deck.
Any help appreciated. Cheers guys.
https://www.sau.com.au/forums/topic/454457-rb25det-rebuild-issue-help/
Doesn't seem possible. Are you sure that they are normal RB25DET pistons, or is it possible that they are for a Neo?
If they are the correct pistons, what is the value of the volume of the "dome" portion of the piston? We can neglect the slight poke of the piston out of the block and use the normal 25 chamber volume and the dome volume to calculate what the CR theoretically is.
  • Like 1
Just doing a real quick and dirty calc, ignoring deck height issues and the gasket thickness, the 63cc chamber, 416.3 cc swept volume and 8cc domes gives 8.56:1 ratio. So close enough to the 8.4 reported before.
FWIW, doing the above with Neo 51.5cc chamber gives 10.5:1.
Ergo, it is hard to believe that these are 9:1 pistons under any circumstances.
Yes
It's wierd
Yep, just got 8.48:1 using a 1.0mm thick gasket
Good on you or your builder for actually checking.
I'm betting heaps get slapped together with no idea of the compression ratio.
Very true, I had CP pistons put in my RB25DET and I don't believe the CR was checked.
as unfortunate as it is for you. its good info for anyone wanting to buy CP slugs in the future.
Zebra could you calc using 17cc instead of the original 8cc stated?
The stroke measurements were incorrect in a book he was using or something along those lines? It has now come up with 10.5 compression ratio with taking into account the .029" out of the block.( which is probably from being decked too much)
Head cc is 62.8cc
Edited by Muskett
9.9ish:1 using a 1.0mm gasket and 0.8mm out the bore
edit, given that the piston is 0.74mm out of the bore, it works out at 9.84:1 with a 1.0mm gasket
1.3mm gasket is 9.53:1
He came up with 10.5:1 with the standard nissan gasket and the 0.74mm out of the block ( obviously can't use this combination but for calcs)
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
