Something a bit left field, thought I would share the massive task we are undertaking in setting up and building a Factory GT3 program for AC Automotive on their 2014 MK VI Cobra. Not everyday you get to peek behind the curtains of a factory program
As part of their new owners plans motorsport and gt racing in particualr has come up as a way of bringing some attention back to the fact that there are still genuine AC cars being built not everything is a kit car.
As an aero designer / developer this car has been a bigger challenge than getting the Bentley Brick to be conpetitive, due to the strict rules around what can and can't be modified or changed, however 1 small advantage we have is that this car is tiny compared to the others so what isn't ideal for aero isn't impacting as much.
Chassis:
Tube frame production car chassis, is unchanged other than the addition of the FIA rollcage and mounting opoints for the transaxel gearbox.
Most GT3 cars need to go on a large shredding diet to bet down to fighting weight, Given our Cobra is Sub 1 tonne fully fitted out with aircon / radio and leather we have the opportunity to devleop the car with ther weight where it is needed to keep low and central
Engine:
Given a "production" rle set we are running GM V8's as per the street car. Our V8 will be a sister engine to the Corvette C7R that has mad a lot of success over the last few years and performed well in the endurance races
Gearbox:
I'm happy to get an Aussie product in with the Albins ST6 found from teh back of a V8 supercar into the read of the cobra. Mated with a OBR control system for paddle shift
Happy to try and answer any questions and update as the build / development goes on
  • Like 2
https://www.sau.com.au/forums/topic/454477-ac-cobra-gt3/
I am guessing the GTSR would make a 997 GT2RS look boring!
Specs aren't 1/2 bad either:
995Kg, 780HP and 1050NM
Here is our base 430hp one taking on a ZR1
Unfortunately I cancelled my trip last week heading over to Europe to the AC factory on friday :verymad: , as had an change in my business here in Australia.
https://www.sau.com.au/forums/topic/454477-ac-cobra-gt3/#findComment-7494158
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
Need more updates!@!
Sorry Mate, been flat out this year
Due to a huge amount of Interest in a GTE spec from Europe / Asia and America the first car being built ( Started ) is being done to 2016 GTE Regulations and prep for LeMans underway
https://www.sau.com.au/forums/topic/454477-ac-cobra-gt3/#findComment-7568235
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
    • I refer you to this thread on PF, by someone who knows what he's doing. Paints a good picture of the humble AD09.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
