Something a bit left field, thought I would share the massive task we are undertaking in setting up and building a Factory GT3 program for AC Automotive on their 2014 MK VI Cobra. Not everyday you get to peek behind the curtains of a factory program
As part of their new owners plans motorsport and gt racing in particualr has come up as a way of bringing some attention back to the fact that there are still genuine AC cars being built not everything is a kit car.
As an aero designer / developer this car has been a bigger challenge than getting the Bentley Brick to be conpetitive, due to the strict rules around what can and can't be modified or changed, however 1 small advantage we have is that this car is tiny compared to the others so what isn't ideal for aero isn't impacting as much.
Chassis:
Tube frame production car chassis, is unchanged other than the addition of the FIA rollcage and mounting opoints for the transaxel gearbox.
Most GT3 cars need to go on a large shredding diet to bet down to fighting weight, Given our Cobra is Sub 1 tonne fully fitted out with aircon / radio and leather we have the opportunity to devleop the car with ther weight where it is needed to keep low and central
Engine:
Given a "production" rle set we are running GM V8's as per the street car. Our V8 will be a sister engine to the Corvette C7R that has mad a lot of success over the last few years and performed well in the endurance races
Gearbox:
I'm happy to get an Aussie product in with the Albins ST6 found from teh back of a V8 supercar into the read of the cobra. Mated with a OBR control system for paddle shift
Happy to try and answer any questions and update as the build / development goes on
  • Like 2
https://www.sau.com.au/forums/topic/454477-ac-cobra-gt3/
I am guessing the GTSR would make a 997 GT2RS look boring!
Specs aren't 1/2 bad either:
995Kg, 780HP and 1050NM
Here is our base 430hp one taking on a ZR1
Unfortunately I cancelled my trip last week heading over to Europe to the AC factory on friday :verymad: , as had an change in my business here in Australia.
https://www.sau.com.au/forums/topic/454477-ac-cobra-gt3/#findComment-7494158
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
Need more updates!@!
Sorry Mate, been flat out this year
Due to a huge amount of Interest in a GTE spec from Europe / Asia and America the first car being built ( Started ) is being done to 2016 GTE Regulations and prep for LeMans underway
https://www.sau.com.au/forums/topic/454477-ac-cobra-gt3/#findComment-7568235
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
