Something a bit left field, thought I would share the massive task we are undertaking in setting up and building a Factory GT3 program for AC Automotive on their 2014 MK VI Cobra. Not everyday you get to peek behind the curtains of a factory program
As part of their new owners plans motorsport and gt racing in particualr has come up as a way of bringing some attention back to the fact that there are still genuine AC cars being built not everything is a kit car.
As an aero designer / developer this car has been a bigger challenge than getting the Bentley Brick to be conpetitive, due to the strict rules around what can and can't be modified or changed, however 1 small advantage we have is that this car is tiny compared to the others so what isn't ideal for aero isn't impacting as much.
Chassis:
Tube frame production car chassis, is unchanged other than the addition of the FIA rollcage and mounting opoints for the transaxel gearbox.
Most GT3 cars need to go on a large shredding diet to bet down to fighting weight, Given our Cobra is Sub 1 tonne fully fitted out with aircon / radio and leather we have the opportunity to devleop the car with ther weight where it is needed to keep low and central
Engine:
Given a "production" rle set we are running GM V8's as per the street car. Our V8 will be a sister engine to the Corvette C7R that has mad a lot of success over the last few years and performed well in the endurance races
Gearbox:
I'm happy to get an Aussie product in with the Albins ST6 found from teh back of a V8 supercar into the read of the cobra. Mated with a OBR control system for paddle shift
Happy to try and answer any questions and update as the build / development goes on
  • Like 2
https://www.sau.com.au/forums/topic/454477-ac-cobra-gt3/
I am guessing the GTSR would make a 997 GT2RS look boring!
Specs aren't 1/2 bad either:
995Kg, 780HP and 1050NM
Here is our base 430hp one taking on a ZR1
Unfortunately I cancelled my trip last week heading over to Europe to the AC factory on friday :verymad: , as had an change in my business here in Australia.
https://www.sau.com.au/forums/topic/454477-ac-cobra-gt3/#findComment-7494158
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
Need more updates!@!
Sorry Mate, been flat out this year
Due to a huge amount of Interest in a GTE spec from Europe / Asia and America the first car being built ( Started ) is being done to 2016 GTE Regulations and prep for LeMans underway
https://www.sau.com.au/forums/topic/454477-ac-cobra-gt3/#findComment-7568235
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
