Something a bit left field, thought I would share the massive task we are undertaking in setting up and building a Factory GT3 program for AC Automotive on their 2014 MK VI Cobra. Not everyday you get to peek behind the curtains of a factory program
As part of their new owners plans motorsport and gt racing in particualr has come up as a way of bringing some attention back to the fact that there are still genuine AC cars being built not everything is a kit car.
As an aero designer / developer this car has been a bigger challenge than getting the Bentley Brick to be conpetitive, due to the strict rules around what can and can't be modified or changed, however 1 small advantage we have is that this car is tiny compared to the others so what isn't ideal for aero isn't impacting as much.
Chassis:
Tube frame production car chassis, is unchanged other than the addition of the FIA rollcage and mounting opoints for the transaxel gearbox.
Most GT3 cars need to go on a large shredding diet to bet down to fighting weight, Given our Cobra is Sub 1 tonne fully fitted out with aircon / radio and leather we have the opportunity to devleop the car with ther weight where it is needed to keep low and central
Engine:
Given a "production" rle set we are running GM V8's as per the street car. Our V8 will be a sister engine to the Corvette C7R that has mad a lot of success over the last few years and performed well in the endurance races
Gearbox:
I'm happy to get an Aussie product in with the Albins ST6 found from teh back of a V8 supercar into the read of the cobra. Mated with a OBR control system for paddle shift
Happy to try and answer any questions and update as the build / development goes on
  • Like 2
https://www.sau.com.au/forums/topic/454477-ac-cobra-gt3/
I am guessing the GTSR would make a 997 GT2RS look boring!
Specs aren't 1/2 bad either:
995Kg, 780HP and 1050NM
Here is our base 430hp one taking on a ZR1
Unfortunately I cancelled my trip last week heading over to Europe to the AC factory on friday :verymad: , as had an change in my business here in Australia.
https://www.sau.com.au/forums/topic/454477-ac-cobra-gt3/#findComment-7494158
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
Need more updates!@!
Sorry Mate, been flat out this year
Due to a huge amount of Interest in a GTE spec from Europe / Asia and America the first car being built ( Started ) is being done to 2016 GTE Regulations and prep for LeMans underway
https://www.sau.com.au/forums/topic/454477-ac-cobra-gt3/#findComment-7568235
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
