Hooking up elec boost gauge everything's wired but I don't know where to install hose to elec boost reader.
Btw
It's a rb25det Neo with boost t installed.
Tried putting hose in pipe on pipe just next to waist gate. Didn't work then tried on little hose on back of plenum still no go.
I did search this before asking this but no luck.
Thanks for help.
I think the diagram means to get you boost reading from the Fuel Pressure Regulator.
Either way, this is something you should NOT do.
The boost line you originally spliced into behind the intake to get your boost reading is correct. If this didnt work then your gauge is faulty or you've wired the +ve incorrectly.
  • Like 1
I will check tomorrow but like I said one green wire from boost sensor to gauge. And earth and acc power. I used accessory power tapped in to back of cigarette lighter.
Only thing I'm thinking could be I got a dud gauge off ebay.
Stuff elec gauge maybe run out to super cheap in morno grab saas.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
