Hi all just seeing what people's thoughts are and what may be the cause....
I got a rb25 neo with a gt3076r.82 and I'm not getting full boost until 5500rpm...feels way too laggy for me and from my research and what other people have said it shouldn't be so laggy either. I've just brought a .63 rear housing to get better response (not fitted yet) but I feel like it shouldn't be so laggy anyway and maybe there's an underlying issue?? Setups currently making 340kw @17psi.
Some of the Mods are:
New neo engine
Plazmaman plenum
1000cc injectors
Rb26 covers -12 breathers
52mm rad
600x300x100 fmic
One piece cooler pipping
Fpr
6boost top mount
Gt3076.82
Haltech platinum pro
Edited by lusunt
https://www.sau.com.au/forums/topic/454627-rb25-neo-gt3076-issue/
Getting VCT working should be a priority, unless you don't have stock cams?
I believe it will give you about 200rpm more response compared to off.
I would be PM Stao from hypergear and see if he will give you some tips.
The .62 housing will prob get you about another 500 rpm response.
Is it running internal gate?
Try pre loading the actuator
Edit,
Oh yeh, a china spec 3076 will do this :P
Edit again
340 kw with a gt3076 and only 17 psi? That doesnt seem right?
are you on E85?
Edited by jay-rod
Edit,
Edit again
are you on E85?
Well my thoughts were that it should hit full boost at around 4000rpm 4400 at latest
if vct only effects it by a couple hundred rpm then I'm not fussed about using it...
Sorry it's
45mil turbosmart External gate
Genuine gt3076
and yeh e85
Edited by lusunt
Then dont use it, but if you have a neo engine with neo cams, why the hell wouldnt you?
No negatives, only positives???
But yes every 3076 i see has full boost by ~4300 on a rb25
Gate could be causing slow boost, do you have a dyno graph with correct scaling?
Would help out most people here diagnoses issues
Edited by jay-rod
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
