Used Trust Pe2 cat back R33 $300
MOMO 3inch exhaust $150
Nismo Pivot Ball $50
HKS GTRS RB26 turbo kit $1350
IMG_20170702_203941916.thumb.jpg.313f66631d74ccb4fa0f92cabd7029e1.jpgIMG_20170702_203949129.thumb.jpg.dfd975425d15284472f69b4665e62312.jpg
R33 RB25 Trust Oil Cooler and oil filter re-locator deluxe kit - Brand New Not fitted -$ 950
IMG_20170702_202133842.thumb.jpg.d2bbdb4699bc17eb6c20310964644ecf.jpgIMG_20170702_202151898.thumb.jpg.8f0965b37df4b3516439c0dcfb1970bc.jpg
R33 Alloy 52mm radiator used $100
R33 Hel Braided clutch line $80
R33 Series 1 GTR Gearbox good condition no transfer case $500
R33 GTST Metal intake plenum gasket - genuine Nissan only imageproxy.php?img=&key=4b1e78680f916b86  $80
R33 GTR GTS Hiflow Cat $100imageproxy.php?img=&key=4b1e78680f916b86
IMG_20170702_204500717.thumb.jpg.8da352bd4e2b2d232394af0f822ae154.jpgIMG_20170702_204452217.thumb.jpg.b48e6378abb33f72f3a31ef80c835b68.jpg
Suspension
R33 GTST Front and rear Sub frames, lower control arms with Brand new super pro bushes and ball joints, Rear Sub frame has whiteline polyurethane bushes all the control arms were sand blasted and powder coated black, also including whiteline diff bushes all new, Photos were after powder coating and before the ball joints and bushes were installed $1500
IMAG0248.thumb.jpg.7e53320a1c35aca199a16a3d2827814c.jpgIMAG0249.thumb.jpg.66c662920105ed8bdd6f1f9cf665b3d0.jpg
Hicas Elimination kit $150
Interior
Body
R33 GTST side skirts plastic White $150
Brakes
R33 GTST Brake Calipers F+R  $150 a set
ADR approved R33 Braided Brake Lines F+R - Used $100
Wheel
Work Ryver Wheels minor gutter rash all center caps included $500
IMG_20170702_205301842.thumb.jpg.50537cbb70e83f0f91287d795786bf75.jpgIMG_20170702_205330178.thumb.jpg.4a7fd49caca7cf11f405111e8506b31c.jpg
Contact: 040328133one
Note: Happy to post small items, larger items that contain oil wiimageproxy.php?img=&key=4b1e78680f916b86l need to be picked up in Canberra or i can deliver to syd for a small fee.
https://www.sau.com.au/forums/topic/454741-r33-gtstgtr-parts-sale/
no turbo setup?
sorry no turbo setup for sale, replied to all the pm guys.
thanks for the interest, if anyone needs a built motor talk to me!! it can come split up or ready to install and turn key if required.
PS: all the prices that are listed are high, but the more you buy and pick up the better deal i can work out for you and i can do lay-by on the big ticket items.
i also have 2 R33 shells as well if you needs parts
still got the greddy boost controller ?
sorry its on hold untill tomorrow night
Have I read that properly, R34 GTR front calipers and discs $400?
sorry you did, R34 GTR rotors will fit under the GTST calipers with the adapters i have for sale as well
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
  • 2 months later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
