Even so, that's no reason not to balance as far as I can see.
Start with unbalanced wheels and you might get one that's 130g out like mine. That would definitely be noticeable on the front of a car.
If you balance it with 130g of weight, when it moves it might go out of balance a bit. It may or may not be noticeable, but it's definitely not going to be as bad as 130g out of whack.
Edited by hrd-hr30
I definately hear your side of the discussion mate.
I've just never had the need to.
I dunno, maybe just a long run of luck with the Yoki and Dunlop semis that I/we have used? Remember I did say that the more road biased Kuhmos I've used definately needed balancing.
Edited by Marlin
  • 4 weeks later...
bit of a strange result from Lakeside yesterday. Powerhouse 120Y with old school SOHC L20B from an 83 Bluebird with a carby turbo setup running 7psi, so it's no powerhouse. Has S13 front discs (and lovely stock 120Y rear drums lol) and definitely brakes alot harder than it accelerates!
I marked the tyres to see what would happen and the only tyre that moved at all was the left rear. The fronts, which I figured would be most likely to move didn't budge one iota. Just the left rear, and it moved quite a bit. And it has bugger all power!
Tyres were just fitted the day before. Used lube but a very small amount and only on the base of the outer bead
Edited by hrd-hr30
Ron Tauranac was big on dynamic and static balancing - and fastidious on runout to avoid exciting the tyres in his formula days. All the manufacturer's dealers trackside support balances as part of the service, so might as go with what they do.
In the old motorcycle days and particularly mud races > very low pressures, pk screws were often run into the bead through the rim......which would make a nice industrial look on a car!
Beware of using stick on weights on the track. In my experience the wheel gets so hot the glue melts and the weights fall off in the pits. Although that was on a 400kw car on stock brakes at QR....
I put that metallic air con duct tape over them and now they stay where they should. Maybe my tyre place uses cheap shitty weights.
Edited by burn4005
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
