S A U - N S W: April Monthly Meet - Sunday Brunch, Furious 7 Movie & Gtr N1 Showcase!
Ok beautiful. Put me down as a maybe and I'll let you know closer to the day. Seeing as its a day thing there's a better chance I'll be there :)
Also have a spot for you to ride shot gun if you'd like :)
Okay will do.
And thanks for shot gun. I'll let you know closer to the day.
or maybe next meet will be the reveal for the new toy? ;) (Still betting it's an evo :P )
Not much street parking right outside the bunker for 15+ cars, even if there was nobody else around.
There is a parking lot behind the main the strip though, just might be a shitfight organising one big group to head down to Katoomba so I suggest familiarize the route if you're not familiar with the area in case we get separated.
I saw a yellow Evo2 driving thru seven hills today, was hoping it was you but when he drove past me I could see it wasn't
Ohh how I'd love to own a Evo2 (or 3!) there is one on carsales at the moment... Looks very tempting I must say :)
I did buy a new VF yesterday as the new family car.
Annnnnnnd I've double booked myself again =( sorry boys.. Gona have to miss this one too..... It'll be Easter Sunday for me...
(Got a bit too excited and jumped the gun lol)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
