Due to the wonders of cheap LEDs from china, I set about changing a few blown dash lights, only to go ahead and replace about 35 bulbs in the dash, climate control, cigarette lighter and shift lever. The results are quite impressive, I just hope these chinese ones dont blow prematurely. These are white LEDs, which make the gauges appear blue, the yellow lights (such as 4WD, synchro, defrost etc) have a touch more green in the colour (a little strange looking I admit), the red lights appear more pink, while the green lights just appear more vibrant.
If I had to do them in future, I would probably use white for gauges and green lights, red for red lights, warm white for yellow lights.
Also don't use an LED in the low fuel warning light. The circuit always has current running through it and it will constantly light an LED.
https://www.sau.com.au/forums/topic/455523-show-us-your-pilot-seat-lightshow/
  • 9 months later...
Are all those just pop-out type LED's or did you have to re-solder some of them?
Most of mine on the gloria require soldering, which I dont mind doing. But the interior pieces are just such a pain in the arse to remove. afraid im gonna break some.
The lights in the dash cluster are all accessible from the back of the cluster (which obviously means removal of a few interior pieces...annoying I admit). There are T5 sockets on the back of the cluster which twist out and accept a T5 wedge bulb.
I have an aftermarket head unit with its own internal lighting, which I didn't change.
The climate control unit has a number of "neo wedge" bulbs. Normally they take tiny "grain of wheat" incandescent bulbs. I think they are 5mm. You can get LED replacement sets on ebay, however I found that they did not screw in, and so I had to retrofit the SMD LED and resistor into the existing plastic bulb holder. It would be important to use SMD LEDs in the screen area, as you want maximum light dispersion. A regular lensed led will point the light directly downwards, but they may work OK in the lights for the buttons.
The ashtray light takes a T5 wedge bulb, and takes a little effort to dismantle.
The shifter light takes a T10 wedge bulb, but it must be a short one otherwise it wont screw in. I ended up adding a resistor to dull the light, as it was too bright.
Pro level: lastly I replaced the blown "grain of wheat" bulbs in the auto transmission power/snow switch. That requires dismantling the switch itself and creatively shoehorning both an led and resistor in each bulb slot.
I do like that color in the dials; is that just bulb upgrade in a standard dash?
it is not simple LED bulb upgrade. i can't figure out how does it work, but there is LED control unit box out side the cluster. also there is a switch to control the LED brightness.
Some additional control of the led lights would be ideal in most cases, for brightness etc. If I had some spare time and money I would probably use an arduino to take care of the speedo, tacho fuel and temp gauge. I had to rebuild my tachometer circuitry, but it can't be correctly calibrated without some additional mapping, which the arduino could provide.
attachicon.gif24198c.jpg&&0){for(var>
This makes sense now; it's also a complete overlay of the dash face as well.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
