Mike,
Got my package of headlights yesterday on the doorstep.
Thank you for the time and effort taken to wrap and box everything, it was better than Christmas.
To the rest of SAU, this guy is awesome.
Adam
Thanks for the feedback Adam. Glad you are happy
RB25 (without microtech), taiulshaft to suit 25 in 32, front strut brace, and whiteline sway bar - all SOLD
Also worked out that the other RB25 with microtech is actually series one. I had assumed since no ignitor that it was series 2, however after looking at the TPS (its only single fixed plug, with the second plug below on its own wiring - same as RB20) it appears that it is series one, running series 2 coilpacks due to the microtech etc.
All PM's replied.
Also have standard RB25 series 2 unchopped/unmodified loom and computer available.
R32 exhaust as well. No front pipe though.
And R32 GTR turbos
I will open it up tmrw and find out. I'll let you know
I just took the diff out of the car. Its 4.3 ratio (48:11) and def 2 way - can provide photos Crown and pinion gears are perfect, however bearings have a bit of slop and i would recommend replacing. Price drop to $450 because of bearings etc.
All PM's replied.
And R32 GTR turbos
Is that an R32 3' catback exhaust?
GTR intercooler - SOLD
Rear strut brace - SOLD
RB25 tailshaft - SOLD
Price drop on remaining RB25 - Series 1 motor, full loom and microtech computer, adj cam gear, perfectly good running motor. Have video of it running. No turbo, p/s pump or air con compressor. - $1200 neg
  • 4 weeks later...
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
