Hey guys I'm struggling to get my hands on a genuine rb25det water pump, Nissan apparently have 0 stock in Aus and there going for $220 now which is weird cause 2yrs ago I payed $160. I have been looking online for timing kits and found kudos motorsports do a fulling kit including genuine 25 pump, nsk idler and tensioner and hates racing belt and that's going for $426, I can get a timing kit for $155 with all stuff but no water pump, I fpund golebys parts have a kit for $209 with water pump from gmb in Japan but they have formed me they only get rb26 water pumps due to bigger propeller in water pump and that on some 25det engine u have to leave a bolt out of the water pump, I don't Like the sound of this, what are you're thoughts on this
https://www.sau.com.au/forums/topic/456163-26-water-pumps-on-25det/
Just forkout for a genuine RB25 water pump. It will be good for the life of your car (i'm just going to go ahead and assume you will sell it or kill it before you put 100,00 on the clock) is $220 really that much? People on here have used the GMB pumps with success but personally i would just shell out for a 25 pump.
Yea $220 isn't that much just a big jump from when I purchased one 2yrs ago haha and the kudos kit was just abit expensive atm haha, but I ddont even think about just getting the water pump through them and getting the gates timing belt through my supplier
Also I just noticed a shitload of spelling mistakes, so sorry about that
All RB water pumps are the same, RB30, 20, 25 and 26. There are two options available on the aftermarket side. The difference between the two is one, you will have to leave out a bolt on some engines, another is that it bolts straight up with no bolts left out.
Either water pumps will work and will not cause leaks or any mechanical issue if installed properly.
Genuine parts is preferable and yes Kudos Motorsports are great for them. But in all honesty, I work with RBs on a daily basis and there are no issues with the 10mm locator bolt left out. There are no gaps and the face of the water pump overlaps the bolt hole, creating a perfect seal.
All 4 of my cars with RB engines don't have the locator bolt. All running aftermarket pumps with no problems.
Part Numbers:
GWP898 - Gates
PWP898 - Protex
7054 - GMB or ACE (both Jap brands)
With water pump 898, you need to leave out the 10mm locator bolt. 7054 has a elongated hole which allows the slight offset of the bolt hole to fit on compared to the 898.
Send me a PM if you have any further questions. I can also supply timing kits as well.
That is not correct at all.
20/25 are the same. Neo is different. 30 is 6 blade from memory and 26 is seven blade. And N1 is for race applications only as it doesn't flow enough at lower RPM.
Wait I thought 20/26/30 water pumps were the same just 25 pumps were different cause of the small 10mm hole being slightly offset from the 20/26/30 pumps
Yes if you get down to the very fine specifics, but otherwise the same.
Just Jap had genuine water pumps for Rb25's as well, I just got one plus a timing belt kit all up around $400 [sorry can't remember the exact prices]. I had an Rb30 one on with a proper gasket and some sort of gasket goop [i didn't fit it and was away from home when it had to be replaced so was done by a shop].....lasted around 35K before it started leaking out the top. Had a noise in the front as well, sounded like a water pump to me, but won't know till I start it up, the water pump i took out didn't have any shaft play and spun Ok so I think I'll be still looking but who knows these things!!!!
I opted for the one with the 6mm bolt [10mm head] and the slotted hole. See how long this one lasts.
Ahh okay, so apart from being completely different and not all of them being interchangeable they are all the same.
Got it. Good advice.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
