Hi guys.
I'm wanting to replace the clutch in my V as it's beginning to slip and i'd hate for the unthinkable to happen and leave me stranded. Looking to replace with Exedy factory option as i'm not needing anything too heavy duty, naturally looking to source the item as cheaply as possible.
Does anybody know the difference between the Exedy NSK-7422DMF (Australian Market) and Exedy NSK1000FW (US Market)? I'm guessing only the part number given the Nissan and Infiniti coupes are the same car.
https://www.sau.com.au/forums/topic/456361-clutch-replacement/
Great, thanks mate.
After doing a bit of research and having a lengthy chat with my mechanic, I've decided to do the single mass flywheel conversion using Exedy NSK-7454SMF. Are any vendors able to supply this? I've tried the search function but it doesn't seem to be working this morning :closedeyes:
Edited by TUFF_350
let us know how you go with it. when I did my clutch replacement I went with a new DMF as I was scared off by the SMF guys complaining about low RPM gearbox chatter and I didn't want that in my daily..
I ordered my DMF and Exedy clutch kit from USA, ended up just under $1k. Not sure who stocks these locally, but they will be the same as the 350Z..
from here -
http://www.ebay.com.au/itm/EXEDY-CLUTCH-KIT-LUK-DMF-03-06-NISSAN-350Z-03-07-INFINITI-G35-3-5L-V6-VQ35DE-/251932446372
But the exchange rate is going to kill you. I bought mine over a year ago when it was still around A$1.10 to US$1.00
And because the figure will now be over A$1, import duty will kick in!
Edited by sonicii
Well i bit the bullet and just bought this:
http://www.ebay.com.au/itm/EXEDY-CLUTCH-SINGLE-MASS-FLYWHEEL-CONVERSION-NISSAN-SKYLINE-350GT-V35-02-07-/161691050017?pt=LH_DefaultDomain_15&hash=item25a589a021
Awesome price, getting it installed locally next Friday. Once it settles in i'll let everyone know how it goes as far as gearbox chatter etc under 1,500rpm.
I know this doesn't help you much since you have already bought the above kit.. but this popped up on ebay the other day.
http://www.ebay.com.au/itm/Exedy-Nissan-350Z-Dual-Mass-Flywheel-Clutch-Kit-NSK7422DMF-/191578489552?pt=LH_DefaultDomain_15&hash=item2c9af7c2d0
Fully installed and wow what a difference, the car feels brand new and drive-ability is second to none!
Slight chatter below 1,500 rpm is definite, but it's certainly not annoying or off putting in anyway :no:
Also if anyone is interested:
http://www.carsales.com.au/private/details/Nissan-Skyline-2005/SSE-AD-2619110/?Cr=1
I had mine replaced dec 2014 by C-red. They installed the SMF option and the chatter is quite noticeable. With the reduction in rotating mass I have noticed little improvement on acceleration. In-fact the car feels quite the opposite, almost like there is drag in the driveline.
If you ride the clutch in a certain position the car shudders. I'm sure my off-the-line acceleration was better with the stock clutch (prior to wear).
Im surprised to hear that from your first hand experience. Keen on replacing my dmf to a smf, or more importantantly a lightened flywheel, as there has to be a better result.
Everyother car that I have replaced the clutch on, I have gone a lightened flywheel with great results.
mosoto did your kit come with a lightened flywheel?
Yes, iirc they only had the SMF with lightened flywheel option available from their supplier. I must add that the exhaust note has changed which may be coincidence, It's deeper and louder which is a good thing :)
  • 7 years later...
After 186k, slipping clutch( occasional sticking pedal from 160k) I finally changed my clutch to ACS Extreme HD Single Mass. Only driven today but, can say:-
1. no noise diff or chatter at idle (if anything prob less chatter)
2. Occasional light clutter noise on first release. Not always
3.Occasionally light low speed lash, noise, through drivetrain whilst upshifting in corners.(again not always maybe different revs gear change)
4. Slightly quicker (maybe .05/s more responsive upshifts). Generally crisper feel.
5. In gear acceleration from lower revs a bit better.
6. Slightly different noise through the transmission during gear changes both up / down. Not more or less just different.
7. you can service this flywheel/ replace clutch plate - You cannot do this on Dual mass OEM flywheel -such a shame for $2.5k unit. Good HD Single mass is still over 2.1k fitted but many suppliers are quoting the same for both HD’s. Some more for dual.
I only went this way as I think it would improve response on an old engine with a slightly lighter flywheel & so far it feels that way. My car still has a great deal of torque with the exhaust and chip on the timing & having a solid flywheel feels right for it.
Its obviously too early to get a full judgement. So hopefully I’m not spewing in a years time.But the Heavy duty flywheel SM is not too much lighter than the dual and my understanding is the new clutch plate on the SM has more spring & material for dampening to compensate for the lighter solid mass.          (not fully obviously).
Hopefully this helps. Will keep you posted if things change.
cheers
Elie
Nice, good to hear it went well. my DMF has also been fine for the last 8 years.  From what i have heard the heavier SMFs experience less of the chatter issues.
Just one point.  The claim that a DMF can't be resurfaced is a myth, you just need a workshop with the right tools to lock the 2 sections of the DMF together to allow it to be machined.
Hi sonicii, yes thats what I thought and even my brother who’s a fitter just said today anything can be machined.so I’ll edit my pt7.
I’m still familiarising myself with it and must confess its a little odd getting the tiny “knock” sounds randomly, mostly cornering.
UPDATE: The little knocking was the Engine Mounts!. Got No idea why one engine mount was nearly all the way loose! & other half way!!.  Mechanic said he “did not touch them”. Bit of lock tight & tension & bobs your uncle!.
The car now drives with no noises what so ever & smooth as .( other than slight CV/suspension creek that was there before). Very little to no chatter -same or less than original clutch -but as I said above its very early. This clutch holds speed (coasts) well under 60 and the original DM better above 80. You have to adjust driving with lighter throttle on SM & holding it longer on highway speeds.
Mine was done at Oyaji Motorsports & I would  NOT recommend them to anyone ATM. Maurice is in Japan & only have fabricator doing ALL mechanic work, the very little time they are open. I did not know any of this when Maurice quoted!. me. If he’d told me any of this No Way would I have gone there.
They f/d up bleeding the system taking a whole day & half!!. When I told them where the problem must be & was! The bolt below the master was not done up properly! (On them). Then they brushed me twice - saying you need to get familiar with new clutch for weeks /month . Luckily only the second week in I told them something is seriously going wrong & literally had to get the installer in the car again after 10min on the hoist all became obvious!!!..
  • Like 1
    • Impossible to remove the housing while turbo is installed on the manifold on the engine. So I have to do it anyways. I plugged it so there will not be any debris in there. Will vacuum aswell
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
