Morning all ! Just finished my 1.5 hours full body workout [emoji15]
Is there any girls that I can chat with in this forum?
Or can Lachy just put a dress on and pretend to be a girl [emoji28]
  • Like 1
Sydney ! Miles away ! Don't think she want to drive up all the way from there for girly catch up [emoji41]
Awwwww , I like beautiful legs ! What's your girly name ? Put on your dress and we can catch up for hot chocolate sometimes ok [emoji6]
Had a chat with Paulie this morning, gonna have a catch up this weekend.
His wife Lauren used to be on here years ago but not anymore.
Paulie ? As in Paul and his wife Lauren?
So no more girls from perth on here then ? [emoji22]
The only chick I know from SAU is Dif, she lives in Sydney though.
FYI I have great legs that look wonderful in a dress ;)
Gee you have a short memory...
Yep good pair of stumps that's for sure ;)
When do you reckon you and Corey can come up for BBQ?
Talked this morning, he said 2-3 weeks out should be fine. I should be able to do sat 23rd if my parents can look after the monsters.
Suit you? What were you thinking of doing?
Blonde, teacher, black 33
Is it coming back to you?
Oh! I've met her :P
23rd would work for me.
Drinks and this place - http://www.oldfaithfulbar.com.au/
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
