I usually always look at number plates when cars pass me but I looked at the idiot behind the wheel instead.
Was a stupid spot to be going that fast. Well done in an excel but hope he landed in a ditch later
  • Like 1
Well what a big weekend, packed 2 kid seats in the back of the 33 for the first time yesterday. Up to collie and watched the anti lag fellas tear up the track.
Up to swan view in the 33 early this morning, pick up nanna for her 92nd birthday and laughing barrel winery for lunch.
Over to Paul and Lauren's new house (sauwa prez and his better half) let the kids burn up some energy, then cruise through mundaring hills on the way outta perth and back down to bunno. Prob about 670km trip.
  • Like 2
