Hey Colin. Not yet, i picked up an AWD version, but the guy i got it off shift kitted it then ran it with no oil inside. It went straight in the bin with the amount of damage inside
idiots....le sigh. I still don't know what the part number is for the board. Just that and OEM springs would do right?
whats your excuse? gotta stay home to feed the ninjas?
Hahahahahaha nah not ninjas [emoji28] Unless if you change the venue to Clancy's fish pub I'll be there - no questions at all [emoji28][emoji108][emoji111]️
