Oh, here is a photo of the freshly washed R33 4 Door, nearly ready to get some plates slapped onto her. (not embedding because the photo is huge)
Theres so much bird poo burn on her, as well as weird stains that I just couldn't remove and some weird blue-tacky glue stuff that's somehow leaked onto her. My current tools were not able to remove those.
Also plenty of scrapes and dings but hey.... the car was less than $3k and I'll sort those out in time.
http://i.imgur.com/2L4mPAo.jpg
Current plan: Mesh Grill, Remove rear Window Tint and Fit the Wheel Arch Guards. Then either drag my mate around to fix the Electrics, or if he really can't make it, drive the car to KYP, have them fix the electrics and prepare her for the pits.
Take Car over Pits, Get Licensed. If the car doesn't get licensed, fix whatever they want and take it back.
After that I need to save some cash, and then I move on to fixing the body and adding a few things (Reverse Camera, new Head Unit), and then we shall see about making the car perform better.
  • Like 1
Not bad... For a 4dr
Reverse camera? Moar powerz!!
The car has a front mount intercooler, GFB bleed valve, Splitfires, Pod Filter. It's currently running the stock Turbo and BOV. It's also had the Oil Filter re-routed for easier access.
Here is a photo of the engine bay, taken just before I fixed the leak: http://i.imgur.com/8AMJuJm.jpg
Did I mention it was rebuilt 50,000km's ago and was resprayed candy apple red? along side all new piping (which was tig welded, but needs a polish).
It's plenty fast enough for now.
Truthfully, I have no idea what to do with the engine...bigger turbo? aftermarket B.O.V?, ECU + Tune?.. no idea yet.
Things I definitely want: Coilovers and Sway Bars, New Breaks + Rotors, Braided Break Lines.
edit: fixed some bad spelling
Edited by Manne
  • Like 1
Def ask before spending on engine. Trap for new players is that many advertised parts on eBay etc are crap. Not crap built but design. Standard bov is fine
Many threads with newbies who bought a tone of cheap engine parts then join Sau to find out why their car comes onto boost at 6500rpm and only has 250hp, if it didn't blow up first
Good plan right there. 25's respond to minimal mods half the time, quality high mount/manifold/gate/exhaust/injectors/ECU. Got one down here putting out 600hp with standards internals bar head gasket and cams
  • Like 1
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
