Just now, t_revz said:
You asking or telling?
I'm planning to do 2020 Olympics
I'm telling. My mate Brammers and I have decided we're going.
Gonna' start planning the trip/accommodation about 2 years out, do you reckon thats a good idea?
Going for Olympics or different part of the year?
Olympics. He's never been to the Olympics before and we figure that Tokyo will be the smoothest/best run Olympics in the forseeable future. Not to mention we'll have a kick ass basketball team!
Drinkin Sake with the mafia!!
We can help you plan it. We will prob start planning a year beforehand. We will be there for a bit visiting family down south before or after
Killer! That'd be awesome if you could help where possible. He's been to Japan before but it will obviously be a bit different planning for the Olympics.
5 minutes ago, t_revz said:
Come down here anytime your ready for a sleepover would be easiest. We can get out the map and see what works
I'll get the Datto sorted, bout time we hit the pub!
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
