Yeah, got 150m2 to do, then potentially the driveway down the track which would be another 300+m2
That's one big job for you , do it by your self ? Hope you have all the dingo / tools that you need - and good luck ! Post some pictures before and after [emoji41]
Can someone help Martin@Shoey please ? He can't access to the site at all. Not sure if it's the same case happened to me couple
Weeks ago
Back now, weird cleared the cache on chrome then it was all good in app and chrome [emoji53]
  • Like 1
19 minutes ago, z00key said:
Sounds good
Killer.
Well I'll do the first thing first and work on my current idea which I'll aim for the weekend of the 19th or 26th of March.
  • Like 1
So glad we have a bunch of new people on the forum that are keen to get out and do something. There were so few of us over the last few years it was just 3 or 4 mates doing catch ups over a few beers lol.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
