2 hours ago, Manne said:
anyone know any good car painters? Chasing Quotes on fixing the scratch on one of my doors.
vulcan panel and paint on vulcan road canninton.
Edited by R33kizza
  • Like 2
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
