3 days of no hot water and nobody seems to think its a big deal... the plumber has said the system has failed and needs to be replaced... and then nothing... have called for updates and nobody will call back...
and to make it worse the thing is banging away on the roof and sounds like its going to explode :ermm:
On 2/26/2017 at 1:34 PM, z00key said:
The RX7 was nice, but my fav was the XB coupe
That's my mate John's car (The RX-7), definitely had some money spent on it!
Are u sure thats not u banging ur head against the wall? Never trust a tradesman lol
52 minutes ago, R33kizza said:
Your a gd one, obviously ur plumber isnt...
had a phone call at the end of the day from W.a.rep. he wasnt aware a plumber had already inspected it and had only just been told. he got me to photograph the ID plate and put the warranty claim through immediately. they are hopefully bringing a temporary system tomorrow for us to borrow until our new replacement arrives on tuesday. good to have results but why they bother lying to take the heat off themselves is beyond me.
  • Like 2
Thats a pretty gd result! Cant ask for much more than that! Some people would rather lie about it than take the blame, but to be fair thats the society we live in now days
That's true but by making false claims, especially in a time of need, people get false hope and frustration ends up being worse by the lack of results
  • Like 1
Exactly that ?
Morning boys ,
I had fantastic time at Adele concert last night ! 65k people turn up and traffic is ridiculous !
At John changing new shoes for 35's [emoji24] and off to meeting soon with Mr.X IMG_5545.JPGIMG_5517.JPGIMG_5550.JPG
  • Like 2
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
