5 minutes ago, t_revz said:
thats bullshit!!
did you get his rego?
Didn't get the Rego, I was inside at the time, just happened to be walking past my front door as he leaned out the window and threw it. Filed a police report, have the bottle, but they said it's too expensive to test the bottle and they "probably" wouldn't get anything off of it. Insurance won't cover it as I only have third party on it.
If she didn't mind, would you be interested? Or too crazy for the street?
It's a little too crazy for the street and only has a 2 speed box, I would have to do mods to make it Street able but that just seems wasteful
  • Like 1
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
