Hahahahahaha unfortunately yes Trev sorry !
Dean bought brand new HRV - cash sales [emoji4] IMG_5925.thumb.JPG.01f3901aaa59bef2b854001aede50de4.JPGIMG_5924.thumb.JPG.7daf511c223b3df29fe9c2ec6281b2ac.JPG
Picking up today at Honda by 2pm [emoji4]
Trev this is for my cheap run around - daily use [emoji4]
Dean bought? You mean Dave? Getting all your boyfriends mixed up :)
  • Like 1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
