7 hours ago, Shoey84 said:
1490238094023.jpeg this ones stuffed
have you got a short shifter?
do your tweeters have a lip so they can be mounted through the door?
is that a shift light off the A-pillar?
whats sitting on the vent near the A-pillar?
Yep its a short shifter.
Umm not sure about the tweeters will have to have a closer look.
Nar no shift light.
The vent is missing all together
4 hours ago, t_revz said:
very convenient
i smell a rat
I have "Small focus of medial facet retropatellar chondral fissuring and basal chrondral delamination" this is caused by the concrete floors at my work and the constant kneeling, squatting, climbing ladders etc... I'm essentially a cripple on a bad day.
Worst part about this is, I made a claim to my work about it, and ever since they've been doing EVERY THING in their power to try and fire me, each week they get closer and closer to it, I sneeze in the wrong direction and they investigate it. The Area manager told the Assistant Manager today "I won't stop until I get him!".  It's ridiculous and i'm not qualified to do anything else.
f**k man it's called unfair dismissal if they do that to you
f*cking p1gs stickered the R34 tonight while the wife was on her way home! Didn't like the lights and they think the engine leaks oil WTF!
Ah man that sucks. It's why I don't use my car often.
Geez he sounds like a top bloke. As long as it's been brought up before they can't say its caused by something they catch you doing in the future
it's not my managers fault, he's a decent fellow. But the 2IC and 3IC go behind his back straight to the Area Manager etc... it's work politics, it's bullshit and I'm sick and tired of it...
f**king shit dream boats, Should be able to get it off easily. FYI you will need to acquire a permit for the intercooler as a modification been done to the car.
There's a form online some where if i get a chance to look today I will send you a link.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
