7 hours ago, Shoey84 said:
1490238094023.jpeg this ones stuffed
have you got a short shifter?
do your tweeters have a lip so they can be mounted through the door?
is that a shift light off the A-pillar?
whats sitting on the vent near the A-pillar?
Yep its a short shifter.
Umm not sure about the tweeters will have to have a closer look.
Nar no shift light.
The vent is missing all together
4 hours ago, t_revz said:
very convenient
i smell a rat
I have "Small focus of medial facet retropatellar chondral fissuring and basal chrondral delamination" this is caused by the concrete floors at my work and the constant kneeling, squatting, climbing ladders etc... I'm essentially a cripple on a bad day.
Worst part about this is, I made a claim to my work about it, and ever since they've been doing EVERY THING in their power to try and fire me, each week they get closer and closer to it, I sneeze in the wrong direction and they investigate it. The Area manager told the Assistant Manager today "I won't stop until I get him!".  It's ridiculous and i'm not qualified to do anything else.
f**k man it's called unfair dismissal if they do that to you
f*cking p1gs stickered the R34 tonight while the wife was on her way home! Didn't like the lights and they think the engine leaks oil WTF!
Ah man that sucks. It's why I don't use my car often.
Geez he sounds like a top bloke. As long as it's been brought up before they can't say its caused by something they catch you doing in the future
it's not my managers fault, he's a decent fellow. But the 2IC and 3IC go behind his back straight to the Area Manager etc... it's work politics, it's bullshit and I'm sick and tired of it...
f**king shit dream boats, Should be able to get it off easily. FYI you will need to acquire a permit for the intercooler as a modification been done to the car.
There's a form online some where if i get a chance to look today I will send you a link.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
