7 minutes ago, R33kizza said:
Now thats a mess lol
the worst mess ive had to fix was a car that hit an island at 100km, bent all tie rods etc, then tried to drive home.
it grabbed the harness in the wheel arch and pulled the harness out of the cab and wrapped it all up around the wheel
  • Like 2
3 hours ago, R33kizza said:
Gotta hate the bacon, got nothing else better to do.... Bad news here too, something's let go on my car and its using alot of oil and occasionally blows lots of smoke ?
atleast if its only occasional it may not be major failure
  • Like 1
some people are morons, they are lucky cutting corners didnt result in the car shutting down in the middle of nowhere
only things worse is scotch-locks or twist-n-tape
Its going to be a few hours of fixing that up..[emoji29]
Cut solder heat shrink or see if i can just replace the harness if im able to
20170324_182342.jpg.019d54c3969a9b52b45e52b25cdbcc7f.jpg20170324_182342.jpg.c7e893fed4f222c1c2b63873960f6dc1.jpg
Why would this have been done like someone seriously needs a bitch slap.
Now i have this mess to clean up.[emoji29]
Side cutters and wire strippers will be blunt by the time you've finished. I've found the dude who did this to your car man. The nutty professor auto electrics. download.jpeg
  • Like 1
I'm running the hypergear art43ss2 turbo with a stainless oil feed and blitz boost controller on the rb25. No probs so far. Solid and strong.
340whp at 18 psi on stock internals. I would agree with the solder and heat shrink. Mate your not alone. I had to rewire tons of stuff under the dash, in the engine bay, in the valley to new ignition coils, the stereo and amps and the hicas. Thank the son of rajab the ecu with nistune was all good. It's a part of owning a animal that has been molested by a freak. I had a load of rattling coming from under the dash and when I pulled it everything almost dropped on the floor. The best thing I done before I started was to take out the front seat. Lying on my Back for hours. Madness!
It's taken about 3 months of solid weekends to make it into my own reliable car that I trust. The big test was the Albany trip to race wars. So when we got home it was a full weekend of chasing down rattles squeaks and squealing. Probably about another $1500 at my mates panel shop and she will finally be the woman I've always dreamed of. Lady smurf with a tan!
When I typed in the son of God it changed it to rajab. Who is this? What's your operating number?
Wtf how dare my phone change God to rajab. I find this deeply concerning?
Has anyone been watching the 24/7 F1 channel on fox 5. 1988 MP4-4 ayerton senna. Left foot clutch right hand 6 speed H pattern. Adjustable boost two not run out of fuel or bust the engine the only restrictions. Pure racing controlled by the driver. Nearly burst into tears when I seen alain prost on the television today. Have been recording the F1 since 1982 when we got a vhs and I was 7yrs old. Allan Jones and Daryl Eastlake aussie coverage. with Murray walker and James hunt commentary. Real racing on channel 9 at 2a.m.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
