Morning all!!
I may need help getting this red beast over the pits, my tyres are slightly too big as the guy that recommended them was unsure of the size I needed and I had no idea. So I may need to borrow someone's that are the right size [emoji7] (name your poison). Also I may need to source inner guard liners for the front as it was rubbing the shit out of them so they went in the bin [emoji24][emoji24]
Will know more after first inspection this week, wish me luck!!
I have my factory rims with brand new rubber all round on em if u want to borrow
  • Like 2
35 minutes ago, shoey85 said:
That sounds like a good option no need to swap with another car
Not sure if KYP still have any but give them a call for the wheel arc liner? I know they recently cleared their workshop of a lot of things so may not have them anymore.
First call I made and no luck but@shoey84 suggested rubber that could work well
You have -5's?
Thought you had n1's?
Garrett 2860-5 turbos
Trust hard intake pipe kit
HKS dump pipes
HKS front pipe
Hi –Flow cat (Venom)
Tomei Ti Extreme – 3.5” titanium cat back 110mm intercooler.
Very flowing now got to save up and do my head port polish n 1mm oversize that would be my dream and cams n lots of stuff thats out of reach haha [emoji12]
Holy moly this probably will get sold in a week just got listed today! I recon Friday it will be sold.
Check it out
https://carsales.mobi/cars/details/_/OAG-AD-14505452?WT.seg_4=AutoAlert%3BPCAA
Wtf thats gotta be a error? Tempted to buy to invest in? Anyone wana loan me 20k?
  • Like 2
Check it out
Very tidy
  • Like 1
What power?
340whp@18psi. It was on the dyno in September. Since then I've done the coil packs, plugs, re routed the intake and inter cooler pipe work and made a new 3" exhaust with a 100cell cat in full s/s.would be nice to think it's making more more now but probably not? Will spin the 245's between 5000-7000 in first under acceleration, chirps second hard and lights up sometimes. It was on a dyno dynamics so plus 15% would be about 390@ the crank. Good enough for now on stock internals. Not a drop of oil in the catch can. No blow back so a pretty safe tune. The oil has been clean as for a bit over 5 thousand ks. I've got a new d-max ute for work so it's only something to play with on the weekend. What about your Nissan?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
