If you're actively working as one, I'd love a quote on my skyline.
Unfortunately not any more.
I left many years ago but have painted a few cars at home for family. Last one was shoey87 nissan pulsar sss with a sr20det conversion. One befor that was my dads triumph sprint 1977 full reso running a sr20det. Both where flow coated and came out like glass
  • Like 1
Fair enough :96_ok_hand:
Any pics of the triumph?
  • Like 1
On 3/27/2017 at 1:22 PM, pol1on1 said:
Garrett 2860-5 turbos
Trust hard intake pipe kit
HKS dump pipes
HKS front pipe
Hi –Flow cat (Venom)
Tomei Ti Extreme – 3.5” titanium cat back 110mm intercooler.
Very flowing now got to save up and do my head port polish n 1mm oversize that would be my dream and cams n lots of stuff thats out of reach haha emoji12.png
1mm oversize i doubt would be required unless aiming north of 800hp. bigger ports n valves means more flow but the airspeed slows down and sometimes wont mix as well. bigger isnt always better. i would definetely research more before going down that path.
HeadTorque in Ossie park did port n polish and modified the chambers on mine. they were great to deal with
  • Like 1
On 3/27/2017 at 7:22 PM, pol1on1 said:
I got 19psi on stock internals 412hp just slaps some sticky slicks on and say bye bye to the lumpy v8 that thinks his cool!
Haha
you must have a heap left in it. -5's are good for around 400KW at the wheels IIRC
  • Like 1
so i setup the Water/Meth on my Rodeo before going away Monday,
holy fark it makes some powah now!!! as soon as the pump kicks it, boost jumps up about 4psi and it pulls like a train. Id say it makes 30-40% more powah now. i just hope it doesnt throw a leg outta bed :blink:
  • Like 1
30 will bust it [emoji4]
Pffft
I had more than 42psi and it didn't bust, it just threw raw unburned fuel out the exhaust as it was so rich and timing was so retarded.
It made more than 42 but I don't know how much as that's as far as the map sensor read. Still made 300kw at the wheels while doing it too.
Just now, TiTAN said:
Pffft
did you go full retard?
  • Like 2
naa, it fluctuates when i move the cable at the pyro. Id say cos the engine rocks lots at idle the cable may have failed. i just fitted a new one and it only lasted 2 days. ill email to see if there is warranty
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
