@turboedsloth Hey Corey, off the top of your head do you know the catch can capacity? i filled it in 400km. im going to fit/modify baffles in the rocker cover next week.
PS i need to take you for a drive and show you how much the methanol injection affects my ute :D
Go hard or go home!
U shouldnt need over sized valves, just a port clean, polish and port match.
Anyone on Instagram?
I made near 400kw with nothing but better valve Springs to hold more boost. No porting or cams or valve upgrades, not even port matching, Just extra boost.
394kw @ 26 psi on a 25/30. Gt35r (2007 spec) 6boob manifold, 3.5" exhaust with 2 massive mufflers so it was 90db @ 3500rpm, 4" intake, 3" intercooler piping, 4" Chinese ebay intercooler and a legit greddy intake manifold with q45 TB.
Everyone needs to stop being so girly with their boost levels, turn it up till it stops making power not some silly oh I can't have more than 20 attitude.
Learn to not fear the boost but instead embrace it and make bulk midrange power with all that extra air.
  • Like 2
I couldnt agree more, im the uk we turn it up and see what happens. If it holds 3 bar then it holds. If it blows ic pipes of u have the tools in the glove box to refit and if mr rod and piston make a sharp stage right exit u call a tow lol
Whats the point in paying all that money to go small? I can understand the risk factor, drop all that cash and watch it potentially disapear up in smoke but i guarantee ul have a big old smile on ya face ?
  • Like 1
Whats the point in paying all that money to go small? I can understand the risk factor, drop all that cash and watch it potentially disapear up in smoke but i guarantee ul have a big old smile on ya face [emoji16]
Im guessing no wife lol
  • Like 1
Married for 5 years and about to buy a house lol i just dont see the point in building a motor to hold say 600 hp and then only run it on 350 or 400, u mite aswell build it to that level and save urself the cash
  • Like 1
Reliability coz i want it on max psi setting always so every turn i do i give it to it.
Not a one off thing when i see a falcoon.
Standard gaskets n studs ?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
