8 hours ago, pol1on1 said:
Reliability coz i want it on max psi setting always so every turn i do i give it to it.
Not a one off thing when i see a falcoon.
Reliability comes with the build, u wouldnt build it for 400 then try and run 600? Which is what most inexperienced people do
1 hour ago, shoey85 said:
Cheers man but I'm looking to leave whatever I get in there
Well i could sell you them? They have caster adjustable nolathan bushes in them. 30 bucks? Im going pillowball mount all round when i actually get a break to fit them lol
[mention=143902]shoey85[/mention] I have a spair left hand wheel arch liner for a R33 but as far as I'm aware the 33 and 34 are the same. It's yours if you need it.
Ok cheers man I may have sourced some but this could definitely help! Will let you know [emoji1303]
  • Like 1
