12 minutes ago, t_revz said:
now you just need WMI :15_yum:
What i need is to find a bag of money to pay of all the parts i need. The turbo i brought was the best but better then my 176k one and my engine is showing it age too
  • Like 1
Morning All !
Very proud of you Lochy! [emoji1320][emoji1320][emoji1320][emoji1320] And thank you for joining us.
Next running events coming up, Martin You Are Next x
No chance cycling is my thing not running! [emoji1303]
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
