4 hours ago, ElleAli76 said:
Aha for me to have fun , and for you then find out lol emoji23.pngemoji23.pngemoji23.pngemoji23.pngemoji23.png
Go Karting - adventure world , movies and pool
your a month too late for adventure world...its too cold now.
im a bit jelly of go-carts :ermm:
  • Like 1
Awwww don't be jelly , you can dress up as Mario or Luigi and ride the go kart on the actual road with other cars at roppongi Japan [emoji7]
still unsure of our plans once we are there
if we get to tokyo id like to stop at fuji. its out of season to climb the mountain but there is a super GT race on
You're there like 4 weeks :) plenty of times to climb Fuji :) oh and all shops stay open [emoji23]
1 hour ago, ElleAli76 said:
Asahi factory ? Cheap booze ? Trev have you try their sake testing ? Is it any good ? And where would you reckon the best one to go to ? What's disaster training centre ?
i think they do beer samples and explain how it all works, i havent drank many sake. i prefer Sho-chu which is similar tho.
the disaster centre has a simulated typhoon and earthquake room and how to survive natural disasters. apparently its pretty entertaining
  • Like 1
Cheap booze in Japan , especially Gin , can we bring it back in the luggage ?
you just have to drink as much as you can while your there :)
naa im sure you can bring 2 litres back per person
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
