DSC_0288.JPG.2d612e8f3a4019abce5b21dd450f2561.JPGCheck the tube out. (from the Dennis) Intercooler to manifold intake pipe on the charge air or boost side were 4" o/d. Because the intercooler outlet and the manifold were cast pipes the I/d of the cast pipe was approximately the same as the I/d of a 3 1/2 inch 16 guage tube. They have had problems with the 4" Ali tubes being worn through and cracking from the compressor lines of the Cummins engine wearing through and losing boost pressure and rattling. I left the tube running off the intercooler at 4" like a plenum then reduced it to 3 1/2 to clear the chassis rail and compressor tubes. Still had to press a flat in it for clearance at 3 1/2 inch o/d s/s. We had to lift the chasis from the leafs just to be able to manoeuvre the tube in with a porter power because the 2ton forklift couldn't lift it. Developed 3 tubes from 316 s/s, done the drawings and jigged it up. 2 days. Tighter than a nuns I'm there. Mental.DSC_0292.JPG.934e33e1b2456435ed5f1f9d61aedce4.JPG
Hey if i were to ask nicely what would I be looking at roughly for you to make me up a intake pipe (replace the plastic/rubber one) with i nice one like this. Your fab work looks awesome
Thanks. At work we sell all the s/s m/s Ali tubing and bends. Plus all the silicone hoses. Clamps, reducers and what not. I'd have to have a look at what you want then get you the gear at cost pricing. We only do heavy duty or mainly diesel stuff at work and I wouldn't recommend the labour costs! But would be happy to have a look and try to help you out! I've got heaps of stuff to fix on the 33 but going into work on the weekend bums me out. Is it 3" piping?
It would be from turbo to air filter chances are would be same as your 33?
Scottynm35 makes them from Ali n ships them over. He has a jib set up to suit most models. He also puts in small return pipes if required for blow-off valves and whatever else is required. I'd reccomend waiting til you replace turbo to reduce modifying twice. I got mine from his aswell as hundreds of others
  • Like 2
Ouch!
Ouch!
Sorry didn't mean to cut you out, just thought it might be more effort getting angles aligned with his car etc where someone has already figured it out and charges decent price for ppl on Sau.
Sorry mate
  • Like 2
Sorry mate
All good. I've got 3" Ali off the intercooler and 3" s/s In the engine bay. The 304 s/s is more heat resistant and less prone to cracking than aluminium. The aluminium will get a better smooth penetration on the inside of the tubes compared to stainless unless you purge weld it. Also aluminium is lighter. Or you would have to use different s/s filler rods that we don't have at work anyway. No cut out at all. I've still got loads of jobs on the car that need to be done at work and can't bring myself to head in on the weekends. I did my apprenticeship at opposite lock/outback accessories, then k&n fabrication as the foreman. I've been at exhaust fabricators/ engine protection equipment for 18 years as the foreman. If someone else has it jigged up for cheap go for it.
That looks awesome, only difference on mine is wouldnt need the maf. If you could give me a ball park figure (you can pm me, private message) or just post here as im sure[mention=143902]shoey85[/mention] and[mention=143051]manne[/mention] might also be keen?
Nah I'm good mate, mine doesn't need fancy pipes
    • No requirement for JDM vehicles,  which the 33 is, maroney label only needed in the US market for new cars I believe (Federal law stuff) Google knows all
    • Hopefully you can just unbolt them, thank them for their service, then bin them and not replace them Apparently the sensors like to set them off with only minor impacts at low speed It looks like they do a delete kit for some of these, but, it is costly
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
