6 minutes ago, Hank Scorpio said:
You'd love it then
you know i would....ill keep an eye out next time i go shopping
saw heaps of HAWT 1200's in Japan. all in traffic but so no photos to share :(
  • Like 1
Yeah, they do the Sunny ute properly over there. Maybe one day...
@ElleAli76 just saw on the news they are reviewing the Mario Carting in Japan. they said there have been too many near misses and they apparently they dont have seatbelts either?
not sure if the seatbelts will be enforced or the whole thing shutdown in the near future
  • Like 1
I had a read on some pages that 7k + or it will bog depending how much slip u give.
i do have nismo twin plate so it bites a little bit if im not careful. Need to practice i think which road...... i think the swan valley has enough of hot laps already.
You can keep the revs up and slip it till you are decently up to speeds where the motors making boost.
It's gentle on the rest of the drive train but savage on the clutch.
It's nicer on the clutch to have lots of revs and dump it, not so nice on the rest of the drive train.
Or you can be a girl and take it easy, by far the nicest option as far as the car is concerned but harmful to others opinions of you.
  • Like 2
2 hours ago, pol1on1 said:
Anyone know how to launch my AWD i know not to rev max n dump my clutch or bye bye expensive parts.
Look at ur dyno plot, pick the rmp where the car is making about half boost, that will be ur launch staging rpm and initial launch. Then its a case of slip the clutch and nail the throttle when the light goes green. Try it at some traffic lights to get used to the ideal clutch biting/power point, ul know when its right as the car will be hooked up, on boost and rolling hard.
Obviously its a feeling that only u will find out, each car and person will be different.
  • Like 2
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
