Look at ur dyno plot, pick the rmp where the car is making about half boost, that will be ur launch staging rpm and initial launch. Then its a case of slip the clutch and nail the throttle when the light goes green. Try it at some traffic lights to get used to the ideal clutch biting/power point, ul know when its right as the car will be hooked up, on boost and rolling hard.
Obviously its a feeling that only u will find out, each car and person will be different.
Now i wish i had a dyno sheet.
Cheers 4 help [emoji4]
[mention=139458]ElleAli76[/mention] just saw on the news they are reviewing the Mario Carting in Japan. they said there have been too many near misses and they apparently they dont have seatbelts either?
not sure if the seatbelts will be enforced or the whole thing shutdown in the near future
Nooooooooooooooooooo they can't shut it down - just make them wear [emoji575]! What's so hard to understand the rules ?
Apparently the latest news accident was last month , tourist Korean lady had a small accident , she's ok tho , but she scratched or scraped few cars along the road lol [emoji23] [emoji594]- silly Korean lady.
The tourists guide or the man in charge is from Australia [emoji1037] and he won't allow you to jump on the cart without a proper license ( international license )
So seat belts is a must ! Or I'll
Strap them ! Lol [emoji38]
Morning All x
14 hours ago, ElleAli76 said:
Nooooooooooooooooooo they can't shut it down - just make them wear emoji575.png! What's so hard to understand the rules ?
yeah it looked like fun on Teli, would be a shame if it completely stops.
  • Like 1
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
