1 hour ago, TiTAN said:
That's a bit like buying a stock car over one with a few boltons.
Clearly you should go for one that's already had the money spent making it better.
its more like not hiring a rent-a-car because it has a pod filter
Is hank away or something?
Also, any brake rotors and pads recommendation? Looking at DBA T3 slotted for fronts and T2 slotted for rears or Dixcel SD/HS (but HS is so expensive).
Pads Project Mu Bspec to go with Dixcel or Red Stuff to go with DBAs
Thoughts?
I have had the red stuff and yellow stuff with the dba slotted rotors.
Reds are a decent low dust pad for Street use. Yellows will take a couple stops before they have enough heat to bite hard, not great on the first few stops in near 0c weather and won't stand up to heavy track use if you have 300+kw, but will do the job if it's mostly stock. you will need something like the blue stuff or just bigger brakes in general if you have a lot of power and want to go hard on the track.
  • Like 1
Thoughts?
My Q1RM pads are great. Would recommend
  • Like 1
Who else is going to the drags Wednesday?
Won't be able to make it (bummer) would like to have another crack at the tree. Show us your reaction times. 11hr day and just got home from bmx. Toasted:-(
Thinking about changing the giant exhaust tip on my car, to a nice sensible twin-tipped muffler.
Anyone have any thoughts on brands, sound, advice?
I just used magnaflow stuff because I got it at cost through work. Does it have a cat in the system? If there is no cat I would definitely go with a reactive rear not a absorptive muffler. I recall seeing a really good looking Lukey muffler tucked away really nice and neat in this thread a while ago?
I honestly don't know, I've never checked as it's one of those things I don't normally care about.
  • Like 1
What rwhp? Does it have a spit dump pipe? Mine had a 3" to 3 1/2" inch when I got it so I just went 3" straight through after the split dump with a 100cell cat skinny long front and fat short rear absorption types. 110kph is about 3000rpm in 5th it planes out reasonsbly quiet but is no cruiser and has nice idle sound. The xr8 is twin 2 1/2" absorptions with 400cell cats and planes out pretty good cruising also and is quiet but meaty at idle. Depends on what you want. So only advice and didn't really answer the question. [emoji16]
The boost psi would be the determing factor from what it needs to push out. I'm only 340rwhp at nearly 18psi and the 3 1/2" fluttered firrrrrrrt pop bang. Doesn't really fart and pop now unless you heel toe the down shifts at high rpm. Pointless owning a skyline without a bit of noise!
  • Like 1
Wheel alignment attempted, works 40k machine doesnt list the r32 or r33. R34 settings used. 2 hours of faffing about and its not much better lol have to attempt it again some other time....
Does it have the hicas or a lockout?
Could take the d-max down if I asked the boss! Lol. Lack of boost night!
Complete lock out, hicas completly removed. Its just irritating that u adjust one thing and it wacks everything out lol
I got 2 sets of front castor arm bushes before my mate Dave measured them to realise they are adjustables off a 34. Show us your actual mechanic! And Frankenstein car!
He aligned it the same day they had the machiene calibrated so is all good now. What do you do for work/job?
Magnaflow would be good :)
  • Like 1
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
