Won't be able to make it (bummer) would like to have another crack at the tree. Show us your reaction times. 11hr day and just got home from bmx. Toasted:-(
If nobody is going I might go fishing instead
20 hours ago, TiTAN said:
They look hideous.
It makes for a rear end only a mother could love.
Bah nonsense they are heaps better looking. Nice clean lines. And that trunk hnnnggggggg
this fireplace would wanna throw out some serious heat after 4 days of f*cking around trying to improve it. even just simple tasks are hard when your jammed in the chimney and can barely move around....
plus just copped a falling piece of flue in the head...so ive well and truly had enough
  • Like 1
Maybe he has run away with Elle?
Hahahahahahahaha He dumped me [emoji24][emoji24][emoji24][emoji24] long time ago , I have no running partner now [emoji28]
He's got new chick [emoji213] [emoji8]
  • Like 1
Elle's back!!
Hahahahah not for long [emoji4] Gtg soon - rock band event at work
Tonight [emoji28] and doc appointment @ 4 !
Chat soon guys
P/s -
Who's going tonight ? And let me know when is the next meet up eat and cruise xx
