I like Japanese stuff, Cusco and Kazama are always good.
I've been meaning to pick up the Cusco rear brace that goes on the back of the 33 strut towers just because it looks better than the top mounted one and matches the front. Without modifying the rear parcel shelf. I put some new rear alpine speakers in the back a few weeks ago and it was a hassle to remove just for speakers. Any thoughts/opinions on what would be the best? I would assume that the top would be the best for rigidity and strength to match the front and the rear for body rigidity? Love the look of the Cusco stuff.
Seems no one is too interested in car talk? I bought a sushi roll a few weeks ago and wished it was a t-bone steak or a t-box or a x-box?
I'm looking at either a Kansai or Autoselect brace for my front and what ever for the rear. Finally got around to rebuilding my front hubs/struts/brakes last night. Time to look into doing the rears
Lol, these were posted 2 hours between each other?
Haven't had much personal experience with rear tower braces an a 33, can't imagine you're going to notice much of a difference between the 2 styles. Which ever one is easier to fit/will work for you.
On 5/20/2017 at 10:19 PM, Beyond Blue R33 said:
We have m.s.t. and s.s.t. at work it's 101.6 mm o/d (4") and 1.6 mm or 16# thick (for exhaust systems) 70mm would be 2 3/4" o/d. And the same thickness. Most stuff to do with heating and flues is 304 s/s 0.7mm thick because of its heat transfer properties. We sell it by the metre in s/s and m/s at work (the 16#) If you know what you want and let me know will be cost price:-) or Jarrahdale heating and cooling or perhaps kounis metal industries have the crimped lapped and swaged 0.7mm at God only knows what price. Will post a pic of the 0.7 crimped and swaged from my heater.
suprisingly, 100mm zincalume downpipe is not cheap from stratco.
$75 for 2.4m
  • Like 1
@z00key  if you dont mind can you check out what these are worth. thanks
Beko DIN38450 14 Place Setting Fully Integrated Dishwasher
Model: 837624  SKU: 837624
Asko D5536FI Fully Integrated Dishwasher
Model: D5536FI SKU: 721345
Asko D5546FI Fully Integrated Dishwasher with Cutlery FlexiTray
Model: D5546FI  SKU: 721346
$75 for 2.4m
I will get you a price on a 3m 4" o/d length m/s and s/s from work which would be 16#. but would assume even at cost price would be expensive. I only build the stuff so have no idea on pricing. The price is saved by using the thinner guage material (0.7ish) and having the proper forming machienes like stratco. Loads of heater shops will carry it in the 0.7mm s/s but like stratco at a profit. I was going to use some 5" 16# tube a few years ago or same stormwater pipe filled with concrete so I could paint it with with marble paint look for AWSEMONESS on my gazebo but just got 100mm square posts sanded them back and stained them in Japan black because was going to cost a fortune in steel or pipe and concrete?
ill hunt around tomorrow for a better deal. surely someone selling the thin 0.7mm stuff has it cheaper than that.
im also going to get the fire at its absolute max with heaps of small stuff and find out the absolute max temps im going to encounter so i know how much metal pipe i need before i can change to PVC.
  • Like 1
Max it out. R+D. Your a animal!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
